Fault code P0687
Fault code P0687
Hello, could anyone offer any advise on this DTC code P0687 showing up on my 2010 BG 1.6tdi. The relay 100 in the engine bay fusebox is constantly buzzing and the engine is well down on power. On looking up this code the explanation of EMC/PCM Power Relay-Control Circuit High is given. Sort of hoping the PCM isn't buggered, Greetings to all and thanks.
Re: Fault code P0687
I would try replacing the relay first up, that might solve your problem.
Will do, thanks for replying.
