turbine wheels
Cabman
turbine wheels
Post by Cabman »
Hi guys im thinking of upgrading the wheels on my 2012 caddy i need to know if a set of scirocco 18 turbines would be a straight fit and speedo be ok
Vertex92
turbine wheels
Post by Vertex92 »
Hey mate
Literally just fitted a set of the scirocco interlagos onto mine and when straight on. As long as the studs and pcd match which should be 5 stud x 112 and the centre bore is the same they’re fine. I think centre bore is 57.1
Fitted mine to 11 plate. No problems either with the offset. I’ll ping a photo over at some point.
Also I checked Speedo with a couple of iPhone apps before and after and made around 1mph difference but I was 4mph out anyway (under obviously)
Along as the rolling diameter is less than 1% I think they’re normally ok. I remember I checked this myself and I think the rolling diameter was just under 1%. Just make sure you get the right tyres
Cabman
Re: turbine wheels
Post by Cabman »
thanks for that mate id like to see a pic if possible :D
Giddy
Re: turbine wheels
Post by Giddy »
I'm fairly sure it's quite a few of them and lots of others in Caddy alloy thread https://www.caddy2k.com/forum/viewtopic.php?f=12&t=797
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Vertex92
Re: turbine wheels
Post by Vertex92 »
Appreciate it’s dark will take another tomorrow Image
Vertex92
Re: turbine wheels
Post by Vertex92 »
Here’s the code for what I fitted
3C8 601 025
8.0Jx18H2 Image
Pinnacle100
Re: turbine wheels
Post by Pinnacle100 »
19’s on mine and they are fine Image
Vertex92
Re: turbine wheels
Post by Vertex92 »
Here’s a link I found useful for checking rolling diameters
https://alloywheels.com/tyreCalculator
