Sdi to pd130 conversion
Iv put a pd130 engine in my sdi I have a edc16 ecu and have put a bxe engine loom clock key and barrel and ecu what is a edc16 ecu iv changed the cam pully and the cranshaft seal to suit ecu and everything how do I do the n57 valve and vac box can u just plug in because Iv been told I need to run a wire back to ecu fir boost but I do no if I do or not can someone help please
Re: Sdi to pd130 conversion
Did you find a solution to this?
I’m doing same at the moment.
- C Chis
The OP hasn’t been back on the forum since posting this, his one and only post so you might not get an answer quickly
