Best oil for 1.6 TDi Caddy Maxi
Hi, I have 2013 Caddy Maxy C20 1.6TDi with 125,000 miles on it. I want to get the best quality oil for it as am doing 300 miles per week in it. What are the best recommendations please ?
Re: Best oil for 1.6 TDi Caddy Maxi
Always go with manufacturers spec imo. Castrol Edge 5w30 for your caddy. Have oil flush & new filter aswell. Hope this helps.
How do you flush an engine. As I need to do this soon.
Andy
Andy
@kilometer . There are lots of brands to choose from who make engine flushing products but basically it's a liquid you add to a warm engine directly before an oil drain. You run the engine at idle for 10-15 mins & it removes (or claims to) deposits inside. When you remove sump plug it just runs away with the old oil.
Cheers mate. Thanks for advice colourpurple
ThaKs for the infos.
Thanks for the info Colourpurple
Andy
Andy
I use Shell HX8 ECT 5W30 for all vw CR engines witouth problem.
