I have had a nightmare day today
I started to fit my new lowering kit, but everything that could go wrong went wrong so after only fitting the front struts, I decided that enough for today, put all the front end back together , found the wipers not working????? so checked all the fuses etc nothing started the van up to move it and it only went about 10 metres and stopped, appears that thefuel pump isn't working??????????
its now abandoned until tomorrow
any ideas lads what have I done wrong and what can I do to get it going again???
Nightmare
Re: Nightmare
sounds like you might have an earth issue somewhere there, its difficult without seeing it here infront of me.
Re: Nightmare
i had this problem other week, check your fuses, one of mine had FALLEN out !
get a meter, put on ground then go along all the blanks, if you get continuity, it needs a fuse, keep turning it over, it will start
Re: Nightmare
Same thing happened me few months ago, doc put up pics of his fuse box for me. Might just have one gone back like i had
viewtopic.php?f=6&t=367" onclick="window.open(this.href);return false;
1.9 TDI Fogs,A Bar,Ply Lined,Tinted Windows,Alloys
