Hello i am still very new to the caddy scene and am getting a set of eibach 45mm lowering springs fitted by VW .It is a newly available
option and wont invalidate my warranty.Does anyone have these springs fitted and are they any good
thanks in advance
Mud
Factory fitted lowering springs ,Eibach any good ?
Eibach make fantastic kit so I've no doubt they are good on the caddy. How do they lower the back?
Re: Factory fitted lowering springs ,Eibach any good ?
Ok this was a question I was going to ask and maybe might be able to give a answer (sort of). Eibach Caddy installation instructions link... http://www.dvsegmbh.info/PDF/einbau/120 ... -02-22.PDF refer to the end for rear install photos.
So it seems they also flip the axle and that prompts my question; is the only way to lower the rear the "flip axle method" or "FAM". I've been searching the forum and it appears to be the method used (apart from a air-ride + 4-link setup of course).
Also notice the "KW" sticker on the plate in the Eibach installation photos. Are they related?
- hedge
eibach uses the kw rear bits minus the shocks, very good kit
Thanks for the replies.I will let you know how i get on .
regards Mud
regards Mud
- lee fowler
I have the Eibach kit on mine, its great.
Lee
Lee
- PhotoPete
I've had a price of £440 plus vat for kit and to fit it, does that sound like a good price anyone?
Where are this to be found these days.... tempted to get them.
Are they significantly harder in ride compared to stock ?
