Used some old bike gear cable to fish the plates for the seat belts in the rear up through the body work worked a treat. Will rivet them in place on Monday
- Exuptoy
Nice job. Where did you get the seat belt anchor/load spreader thing?
Just cut a piece of 50mm wide, 6mm thick plate to length, drilled a hole in it then welded a nut with the same thread as the seat belt bolt to the back of it, drilled holes either side to rivet it in place so I can unbolt it without the plate falling down. Found a good spot to do the bottom one I think too. Will take photos of that when I've done it, probably next week or the week after that'll be though
@exupoty I used these . A bit awkward to fish up into place but once you have them there I nipped the bolt tight to them then used some small self tapping screws to hold them in place
https://www.ebay.co.uk/itm/VW-T5-T6-Cad ... 635-2958-0
- Exuptoy
Cheers @tom.preece87 although I would need to find the correct size nuts.
@Jono1 so I assume it’s 2 x plates per belt? Nice find btw.
The fact I have carpeted the walls gives me another headache but I’m sure I can manage. Cheers guys.
@exutopy
Yeah I used one for the reel one for the top mount
And then just a standard spreader plate with a nut with nylon washer and a bolt for the bottom mount
- Exuptoy
Cheers fella.
- Exuptoy
Could you double up on the reel and lower mount or is that not possible?
Fitted rear seats...
Sent from my POCOPHONE F1 using Tapatalk
- Exuptoy
Nice. I need a life step trim to fit the swb.
Anyone know the part number?
- Cabbs
[mention]Pman1984 [/mention]
Nice job there mate.
My rear seat conversion has been semi complete for a while apart from the seat belt reels. Haha What seatbelts have you used mate and how did you mount them? Any pics?
I have a full set of Touran ones.
I’ll be on with the insulation and carpeting once I get them reels in.
@Cabbs I got a set from a maxi life along with the maxi life seats as I wanted the 3 proper belts in the back. My wife's touran expired and I stripped it out but didn't like the options for middle seat.
The lower mounts I drilled and there was already a strengthening plate in the floor. I then decided to come up from under the van with another spreader plate to bolt into. Didn't take any pics tho sorry, too many swear words and pending rain to take any
- Cabbs
No worries pal.
The mounting of the top and the bottom I’ve done. It was just mounting the reels themselves. The Touran belts don’t quite fit in them recesses where there ment to go. I know there’s people who have fitted them but no pics.
Cheers anyway dude
Cheers anyway dude
@Cabbs the reels are outside on mine like the maxi life etc. Couldn't be bothered with the cutting to get them into the recess.
I put mine into the recesses, did it a couple of weeks ago. Took me around an hour per side. Had to grind some of the plastic reel housing off. I can take photos of that if you like. Mine is a maxi, don't know if that's any different to an SWBCabbs wrote:No worries pal.
Cheers anyway dude
