@RBJ2206 the touran seats don't fit directly to a maxi, they need the brackets cut out of the touran a welded into the caddy. There are a few people on forum who have done it and took pictures that will help make sense.
Sent from my POCOPHONE F1 using Tapatalk
@RBJ2206
you have a standard kombi (bench and single) seat setup so these won't fit your floor mounts...
Yeah the seats are Touran sport one's and i also have the matching front seats .
@vizidomar beautiful colour van
did you code them in ur self
Reason: removed pictures from the quote
Not coded as yet. They just need the right hand reverse bulb error message sorting otherwise perfect
@pizzaman. Are you thinking they're LED mate because they aren't.
no m8 just thinking about buying some mk4 lights but wanna know if easy enough to program in so dash bulb warning doesn't stay on ?thecolourpurple wrote: ↑Tue Nov 30, 2021 6:21 pm @pizzaman. Are you thinking they're LED mate because they aren't.
@pizzaman. From a wiring perspective you shouldn't have any problems. The kit I bought from Travelin lite came with pin removal tool & wiring diagram. Its just a case of moving some of the pins around but due to the right side not having a reverse lamp you end up with a spare pin. You will need to fit a resistor or have access to vcds to solve it.
@thecolourpurple
vcds do it or do i need vag can pro ?
i have a vcds but ordered a vag can to be on safe side so i know i will be able to do thanks for reply
should be able to with vcds
Painted winter shoes
I tried to change my car radio, but discovered I need an extra harness to adapt. It's on the way. At least the aftermarket rad is built in the new frame and ready to go now...
- TheGee
I bought a 180ah alternator from a Passat CC for £30! No idea if it actually fits or not but I’ll cross that bridge when I come to it
Striving for the perfect excess
Fitted some VW Touran leather heated seats! Feel comfortable. Just waiting for the looms and heater unit from Tommyzooom and bought a VCDS cable so can code it myself and for future use
Fitted wiper arm nut covers. Found out ones from an A4 fitted. 8W0955205 for anyone interested
Sent from my ONEPLUS A6010 using Tapatalk
