- gazza31112
@Ripley55 hi mate, my battery has died a few times and never had the engine light come on, mine has been on ever since I overfilled the adblue last time though lol
- Ripley55
Ahh @gazza31112
Strange coincidence, as 3 weeks ago I filled up with Adblue as well, and may have put a drop too much in as well, but didn’t notice a light afterwards, and obviously haven’t been anywhere, can it just be cleared on ignition, or is it VCDS scan and reset ?
- gazza31112
I tried to clear mine but it just comes back, apparently from what I have read the sensor needs recalibrating, you can only refill the amount it says on the dash, I just filled until it overflowed, which apparently confuses the sensor.
Not certain of this, it's just what Iv read.
I haven't bothered to get it checked as my warranty has just run out lol, Iv got a fault code of failure to read NOX sensor b, I assume that's something to do with adblue, but still runs fine.
- gazza31112
And my light came on 2 days after I filled with adblue, not straight away
- Ripley55
That’s it then ? Is it a code it mod, or will it reset automatically once level drops ?
- gazza31112
Mine hasn't reset, I'm now down to 3000 miles remaining on adblue, and it's still on.
I assume it has to be done by VW.
- Oldgregg
[mention]Ripley55 [/mention] The sensor may need replacing or resetting/ recalibrated. From what I’ve heard if you delete the fault code it just comes back. If it’s to do with the NOx sensor that is.
- sheepy92
@Sean1066 Hi sean where did you get the adaptors for back of vents mate could do with some of these myself are they 3d printed
- Papa Bear
Finished the wiring in the back for the LED’s, just need to wire up the switch panel when it arrives.
Started painting a couple of trims to match the headlining, looking good to me.
Will start taking the rest off and paint the bigger bits then I can get it all back together.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Papa Bear
I see Doc is on patrol removing quoted pics
Doc the key worker
Doc the key worker
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Ripley55
People just won’t learn sad really
Replaced rubber fuel hoses badly perished, loads of grief removing the 6 torx bolts on the fuel filter housing and snapped the push in fittings on the breather pipe . Had a look at the state of the whole exhaust system which has excessive patina. Lots to be getting on with.
Attempted to wet sand and polish my other mirror cap, After doing one last week, and it turned out lovely
This one, not so much!
I blame the bright sunshine out on the deck, but I cut through the lacquer in a couple of places, so have had to rub it down and paint again
Oh well, you live and learn!
I have reupholstered the kick panels in the Bay window bus though! Id been meaning to get rid of the rubbish White vinyl for ages, and used some left over carpet from the caddy
- Mk2kompressor
Started with the carpet
Got to wait for a fresh pack to do the rest of the new ply but it’s coming along great now
2.Slow
- Sean1066
@sheepy92.
I bought them of the guy that makes the caddy cup holders.
He sells them on here.
I’ve been trying to find his for sale thread but I can’t find it at the moment.
