Giddy
Post by Giddy » Fri Jun 26, 2020 4:11 pm
Unintentionally tested my brake assist /emergency braking system. It saved my front end I recon.
Instagram: @giddywagen
bradh
Post by bradh » Fri Jun 26, 2020 4:19 pm
New mats and sill protectors installed
Dickiefree
Post by Dickiefree » Fri Jun 26, 2020 4:22 pm
Turned my tails lights from stock looking to red. Loads nicer
Vwjack88
Post by Vwjack88 » Fri Jun 26, 2020 5:23 pm
I tinted a set not long ago, but couldnt get them to flash orange. I tried green bulbs, but wasnt very bright
drew667
Post by drew667 » Fri Jun 26, 2020 5:37 pm
Bradh how much for the mats?
bradh
Post by bradh » Fri Jun 26, 2020 6:42 pm
More than I wanted to pay
I think they were £50
bradh
Post by bradh » Fri Jun 26, 2020 6:43 pm
They do fit really nice and no more having to straighten up every time I get in the car as they fit the original lugs
Beaker2135
Post by Beaker2135 » Fri Jun 26, 2020 8:40 pm
hef355 wrote:
Fri Jun 26, 2020 10:07 am
Great job that Steve, really meticulous like everything you do fair playImage
Thank Hef, I live by my motto KISS :lol:
Papa Bear wrote:
Fri Jun 26, 2020 3:34 pm
I apologise if the weather turns bad now, expect snow!
I’ve just had my air con regassed :D
£48
It’s Biblical here :lol:
tonyhill
Post by tonyhill » Fri Jun 26, 2020 9:33 pm
How, with spray or film? Looks good :D
anoneamus
Post by anoneamus » Sat Jun 27, 2020 10:00 am
They're great, but I've worn a hole in the driver's one near the pedals after about 4 years. Will need to replace. :|
Dickiefree
Post by Dickiefree » Sat Jun 27, 2020 10:08 am
“tonyhill"
I used red tint film, I didn’t cover the whole light I just cut the indicators and reverse light shapes out and carefully applied them. You can’t even tell where the light film starts or ends. Looks really good
Dickiefree
Post by Dickiefree » Sat Jun 27, 2020 10:11 am
“Vwjack88"
I used red window tint film, I only covered the parts off the lights I wanted red, so just the indicator/ reverse light etc.. cut small rectangles. So still mostly the original tail lights showing. Orange shines thru ok on mine still
anoneamus
Post by anoneamus » Sat Jun 27, 2020 10:41 am
Exploring the limits of what a 2WD Caddy can do. Got stuck on a pebble beach, and almost stuck on another road through the dunes. Need to start looking at 4Motion retrofit (although standard height clearance is also an issue).
Papa Bear
Post by Papa Bear » Sat Jun 27, 2020 11:09 am
Spent an hour and a half in the rain removing a ptc heater. Well, when I say removing, I’ve half removed it! Need to go back on Monday with more tools to continue.
Black
Marmite lover!!!
C Chis
Post by C Chis » Sat Jun 27, 2020 12:54 pm
Coded in footwell lights to my replacement CECM this morning.
Tested with a homemade test lamp, well chuffed!!
https://youtu.be/wn1vOgRJ53c]On to off ... the door
https://youtu.be/C79XXgnjweI]On to off ... e ignition
Need to head to the scrappy’s next week to pick up a couple of light fittings from a Golf, pop in some red LED’s and get them wired up and installedImage
CECM was from an EOS, part number 3C8 437 049 E
The differences on plug B (highlighted in orange) were...
Installed a test wire into plug B
Coded the module to my van...
Ran a test, all working as factory, then gave it try, result!!!!
I didn’t change the van to a car in the other CM, left as a van Image
