Caddyluv
Post by Caddyluv » Mon Jul 27, 2020 8:25 am
@matias yeah they are veemann, have a look on my build.
LeeH
Post by LeeH » Mon Jul 27, 2020 2:06 pm
I like the getto anti fall over device on the foam lance.
_Tim_
Post by _Tim_ » Mon Jul 27, 2020 9:28 pm
Removed some 12v wiring from the ex BG maxi.
Lots has just been chopped and left in place (presumably when de-fleeted) so chased and removed 12v cabin lines and found a load of what looks like comms lines(?) Heading up the a pillar and towards the rear.
That'll be tomorrow's job then!
J_Con
Post by J_Con » Mon Jul 27, 2020 10:27 pm
@mikenorman couldn't find you at all on Facebook
Sent from my LYA-L09 using Tapatalk
PaulC61
Post by PaulC61 » Tue Jul 28, 2020 4:43 pm
Used my DI water setup fro the first time to give the Caddy bit of a wash. Normal TDS (total dissolved solids) for the tap water was about 430ppm which meant I had terrible water spotting which was a pain to get rid of. After the water was trickled through the DI filter into a holding tank the TDS is now 0ppm. No more water spotting making the wash process a bit easier.
J_Con
Post by J_Con » Tue Jul 28, 2020 5:54 pm
DI vessel is a great purchase for ease when washing. Couldn't go without mines now even though the water isn't hard where I am
PaulC61
Post by PaulC61 » Tue Jul 28, 2020 6:10 pm
Also did my mums black Passat with the DI water and that is a complete pain to wash. Soon as there is any sun out the body heats up and evaporates the water leaving loads of water spots. The water is so hard here in Norfolk it destroys plastics. We only use stainless kettles with a metal filter, plastic kettles just disintegrate on the inside.
Papa Bear
Post by Papa Bear » Tue Jul 28, 2020 6:24 pm
How long do the filters last?
I usually have 2000 litres of rainwater collected, used to filter through sand for filling the hot tub but mostly used for watering the garden on a timer. Sand filter needs an overhaul and we don’t have the hot tub at that house anymore.
Black
Marmite lover!!!
VCDS
Sean1066
Post by Sean1066 » Tue Jul 28, 2020 7:25 pm
Went and picked these up today hopefully I will get them fitted with tyres soon
Then I can really see what they look like Image
My build thread
Post by gazza31112 » Tue Jul 28, 2020 7:28 pm
@Sean1066 mate they are beautiful
Ps you have my boots
PaulC61
Post by PaulC61 » Tue Jul 28, 2020 8:04 pm
@Papa Bear Hopefully I’m looking to get a few thousand litres out of the system but as usual there will be a number of factors which will affect this. Looking at the TDS readings for my rainwater I would use this but I only have 700 litres for the garden. It definitely helps when wash the motor so I’m happy.
Papa Bear
Post by Papa Bear » Tue Jul 28, 2020 9:49 pm
Get yourself a couple of 1000l IBC tanks :D
Black
Marmite lover!!!
VCDS
DW2207
Post by DW2207 » Wed Jul 29, 2020 7:39 am
Fitted these covers to the pedals. Fitment was spot onImage
mikenorman
Post by mikenorman » Wed Jul 29, 2020 8:00 am
My waters 36ppm off the mains
mikenorman
Post by mikenorman » Wed Jul 29, 2020 8:01 am
[mention]J_Con [/mention] email might be best then if I’m allowed to post it.
mikenorman1979@gmail.com
