Bjoates
Post by Bjoates » Wed Jul 29, 2020 10:47 am
So got my fog lights fitted, got a full service and a new set of German style plates done in the past few days
Next job will be to fit touran bases and seats for Abit more comfort, so anyone that knows anyone that has a set left me know
Sent from my MAR-LX1A using Tapatalk
Jay1182
Post by Jay1182 » Wed Jul 29, 2020 11:32 am
I fitted the mist type water jets off of my Seat Ateca onto the mk4 it was a straight swap and works so much better than the spray lines
Also fitted a Left hand drive rear passenger side light to curb my ocd, now both the reverse lights match up
Will probably move and attach the rear fog onto the bumper reflector
Sent from my SM-N976B using Tapatalk
C Chis
Post by C Chis » Wed Jul 29, 2020 12:01 pm
Went to glue my rear spoiler edge back down, only to discover the whole spoiler was being held on by gravity, eek!
Sealant was still stuck to van, however it had peeled away from the spoiler because I’d sprayed the underneath when doing it, doh!
Lesson learned...
Jca730
Post by Jca730 » Wed Jul 29, 2020 3:40 pm
Annual service and an air con leak test to be told it's the condenser, oh well id rather have cold air than drive around in a metal sweat box when the sun's out. Was also quite surprised to find the service didn't include an air filter or cabin filter, so off to euro car parts to get them.
Sent from my ANE-LX1 using Tapatalk
RedLion
Post by RedLion » Wed Jul 29, 2020 6:12 pm
So much! And all in the sun, being ginger I obviously now look like a swan vesta.
Did passenger touran base, pressure washed the passenger seat, changed a light cluster, cleaned the touran carpets I picked up yesterday and then decided to fit stalks ready for trip comp and cruise. I need a cider now.
Caddylife2020
Post by Caddylife2020 » Wed Jul 29, 2020 6:32 pm
Today I removed the DPF to "clean" it out and also removed the turbo for a clean. Found the turbo to have so much wobble it was touching the housing! so I bought a new turbo cartridge rather than a recon unit.
https://www.ebay.co.uk/itm/321904302814
Not actually that bad of a job to do as long as everything comes loose and doesn't break off. Had to drop the sub frame to get the DPF out but didn't have to fully remove it which made things easier.
As long as you have the right tools it's not actually that bad.ImageImageImageImageImage
Oldgregg
Post by Oldgregg » Thu Jul 30, 2020 6:08 am
The most simple mod I’ve done to date
Plus a smoked centre break light cover
Ryzar1
Post by Ryzar1 » Thu Jul 30, 2020 6:10 am
Managed to get a bumper cheap needs a bit of work thoughImage
Much better than the dark grey bumper
drew667
Post by drew667 » Thu Jul 30, 2020 1:01 pm
battery case just half of work doneImage
tonyhill
Post by tonyhill » Thu Jul 30, 2020 5:07 pm
Do you have a link for the washer jets you fitted? Never realised there was so many!
Ripley55
Post by Ripley55 » Fri Jul 31, 2020 12:41 pm
Fitted Travelin-lite Caddy MK4 sequential/dynamic smoked LED indicators just now, 10 minute job, work a treat with no errors Image
Chestnut Brown Caddy Maxi Life , 19" ZEUS Alloys 8.5J, 235/35/19's, Lowered on Coil overs, Gloss Black Grilles, Carbon Fibre Rear Bumper Protector, Colour Coded Side Rail covers, Colour Coded Door Mouldings and Duck tail Tailgate Roof Spoiler, Colour Cluster, Heko Wind deflectors, W8 Light, Satin Black Roof Bars, Limo tints R Line Badges
Post by petrev » Sat Aug 01, 2020 11:44 am
Travelin-lite again ...
Fitted the T6 rubber windscreen infill strip.
Fits fine with a little trimming each end.
Nice quality heavy rubber.
https://travelinlite-transporters.co.uk ... ubber-seal
Post by Doc » Sat Aug 01, 2020 4:29 pm
That's gonna have a detrimental effect on your ability to defrost the windscreen in winter. Your climate control ducts blow onto that area to keep the wiper blades free from ice and defrost the very bottom of the windscreen.
Papa Bear
Post by Papa Bear » Sat Aug 01, 2020 4:41 pm
Installed the tv, was going to install button inside tailgate to open from the inside but heat stopped play
Black
Marmite lover!!!
VCDS
Post by petrev » Sat Aug 01, 2020 5:28 pm
Well, that is annoying - Hmmm!
