- Caddy Stu82
@Pinnacle100
I had a similar issue a few weeks back. Turned out (as suggested by others) that the new bumper came with a bracket already fitted so the old one attached to the body needs to be completely removed.
Hope this helps
Hope this helps
Thanks caddy stu82. So you removed all the black plastic part that’s mounted to the body of the van , was it just plastic rivets holding it on do you remember?
I’ll remove the bumper again and try that and see how I get on
Got around to a brake pad change.
Think I had about 7 miles left!
- TheGee
Smoothed out the lock hole in my rear grab handle
Striving for the perfect excess
Steels back on with winter tyres... Might need to lift the front a bit tho...
Sent from my POCOPHONE F1 using Tapatalk
T5 steelies for the winter just out of curiosity..
Looks great i think the van suits those wheels . Vans a lovely colour .
- robblowen
@vizidomar I didn't think t5 wheels fitted? They do suit it!
- Giddy
Look-wise they very similar to ATS Cup wheels
T5 steels only have 7 cutouts in that triangle style or 20 in the circle version so I'd say there the ATS versions in the correct PDC to fit? They do look good tho. Really like the Van colour too!
Wheels (and van) look great
Look like steels, and not quite the same hole pattern as the very similar ATS Cup alloys (8 holes).
T5 have wrong bolt pattern I think (&8 holes, T6 are 7), so they must be some other VW at a guess.
Hope someone can tell us the exact right info as they do look superb.
Thanks lads.
They are genuine T5 steels fitted with adaptors in a very rare 16" size.. I should have put bigger rubbers on..
Super rare, and lovely
Today I rug doctored some Touran seats I bought a month back. Fair to say, they were bogging! Pleased with the outcome and they look like new. Now to get the van through its MOT and I'll attempt to fit them myself
Is that a standard Torah rear seat set up in the middle row of Caddy maxi I don’t have enough locating slots in the floor of mine ? I do like them . Do you have your an front seats as well ?Gary.8 wrote:Replaced the third row rear life seat I had for some Touran seats..
just the last bit of rear floor to finish.
Reason: Removed one picture from the quote
