Novakid
Post by Novakid » Sun Dec 01, 2019 10:47 am
That wheels look mint Josh
Josh764
Post by Josh764 » Sun Dec 01, 2019 10:56 am
Thanks buddy, was worried they wouldn't go on,, so glad they have.
Post by gazza31112 » Sun Dec 01, 2019 10:58 am
Yea I like them, fill the arches up a treat
RKDesigns
Post by RKDesigns » Sun Dec 01, 2019 11:06 am
Under a 1.6TDI you can even mount 10J with just a little change to get the doorcard a bit more in it still let fully slide open the slidingdoor. With the 2.0 TDI 140hp 8,5J already comes out
Fonzi
Post by Fonzi » Sun Dec 01, 2019 12:01 pm
Finally got round to changing the rear shocks, old ones had blown :( Image
Beaker2135
Post by Beaker2135 » Sun Dec 01, 2019 7:24 pm
Decided it was cold enough to fit the winters
Ant bliss
Post by Ant bliss » Sun Dec 01, 2019 7:31 pm
Finally got my reverse camera working like Oem big thanks to @r1lea
Then took my back roof lining down to insulate behind it
fazerfreak
Post by fazerfreak » Mon Dec 02, 2019 6:59 pm
Played with the Obdeleven, but used the vagcom to activate « indicator celebration» :D Needlesweep..
Best Regards
Tommy
BillyGilly
Post by BillyGilly » Mon Dec 02, 2019 7:22 pm
Replaced injector seals, oil & filter change.
BillyGilly
2016 2.0 TDI Bluemotion: viewtopic.php?f=13&t=40889&p=341148#p341148
2009 2.0 SDI: viewtopic.php?t=40416
fwi98
Post by fwi98 » Wed Dec 04, 2019 2:49 pm
Sean1066 wrote:
Fri Aug 30, 2019 5:04 pm
Finally got the head unit I wanted and fitted in in today.
Discover media
Hello Sean,
I see that you are in the same case as mine : update RNS510 into Discover Media PQ . But i have a TOURAN MY 2014 . I think i hjave to change my gateway prior to go to VW to ask for Component Protection descativation.
I plan to install a 7N0 907 530 BC. Actually i have a 7N0 907 530 AN and with VCDS i don't see the unit in the "installation list"
Could you tell me , if it's possible for you, if you have this model of Gateway installed in your car ?
Thank you very miuch in advance
Sincerely yours
Emmanuel
Sean1066
Post by Sean1066 » Thu Dec 05, 2019 5:54 am
Hi Emmanuel
My discovery media I bought off spacewalker and it was plug and play and already component protection removed
So I didn’t need.
As for the gateway I couldn’t tell you what model number it is without vcds.
My build thread
thecolourpurple
Post by thecolourpurple » Thu Dec 05, 2019 8:47 am
Took delivery of this.....Image
grav4iks
Post by grav4iks » Thu Dec 05, 2019 2:00 pm
Finally, changed the steering wheel, from B6 Passat R-Line
VW Caddy 2006 2.0 SDI
Audi 80 B4 Quattro Competiton 1994
Post by gazza31112 » Thu Dec 05, 2019 4:50 pm
Removed bulkhead and made a MDF replacement, installed some pioneer 6x9s above headrests
Lost some load space in the back but I can finally put my seat in a comfortable position!!
Carpet the front side next weekend, few shelves to go up in the back, need a MDF VW badge to carpet for inbetween the speakers.
Good day!ImageImageImageImage
Post by the swan fiend » Thu Dec 05, 2019 5:04 pm
@the colour purple, is that a direct fit onto the standard exhaust? If so where did you get it?
