My purple caddy!
Re: My purple caddy!
Love it mate
- ed1119
Id have a go at DIY air install mate, fitting the bags must be like fitting springs/coilovers, then its just a case of interior out and running air lines and electrical wires and plumbing it together. You just need to decide what type of air system you want; as in do you want a simple system to lower for shows and up for everyday driving (2 way, 5 gallon tank, manual switches and single compressor) or do you want all singing all dancing air management that automatically adjusts for weight in the back, has presets for different heights and can be controlled from your iphone/iPad.
I'd probably go for something in between, definitely want 4 way anyway because 2 way doesn't pass the test in Ireland. Just haven't a clue where I would mount the rear bags on the rear beam, and adding in extra support bars and all that on the rear
2011 cadbury purple aired out show van
Awsome van!!
Do you have the wheel and tyere spec? Wide, offset and tyere size.
Best regards
Best regards
Wheels are 19x10 rears 19x9 fronts, think et is 42, tyres are 225/35s. I have my arches widened by around an inch all round ,before I got it done the lip of the wheel was VERY close to the arch. If running low I wouldn't advise running them unless you plan on widening the arches! I think you can get them in 8.5/9.5 widths aswell but not sure.
Very nice.
Lovely van mate.
Saw this on facebook, absolutly stunning
wow what a colour! awesome transformation
- dubstopjames
Very sick.
