My Mountain Biking Camper Caddy build
mrhutch
Re: My Mountain Biking Camper Caddy build
Post by mrhutch » Wed Mar 04, 2020 5:32 pm
lovely build chap..
Did you do away with the pull out second section for the bed in the end?
06 sdi caddy2k :: 81 Transporter T3 :: 2015 Golf 1.4 TSI :: Freelander (sorry)
Herefordshire and all over.
aerobic247
Post by aerobic247 » Fri Mar 06, 2020 6:41 am
mrhutch wrote:lovely build chap..
It’s still on the to do list
my Mountain Biking Camper build viewtopic.php?f=12&t=24530
Drumsmasher
Post by Drumsmasher » Thu Mar 26, 2020 8:34 am
Great stuff. Thanks for those pics, that will help me loads as I’m trying to do the same thing. I was looking at the packs from deadening.co.uk that are 144 quid. Wasn’t sure if they were better/worse/or the same as what you have done. I was worried about loft insulation due to the moisture and the loose fibres but I didn’t know that they did it recycled.
Mouse
Post by Mouse » Fri May 08, 2020 6:59 pm
aerobic247 wrote:running a power cable from the starter battery to the leisure battery behind the seats
still to build a battery box
Hey, did you go through the hole to the right of the cable in pic 1? How/where did you locate the wire on the inside of the van?
Thanks Mouse
Sent from my EML-L29 using Tapatalk
shameus
Post by shameus » Fri May 08, 2020 9:00 pm
There’s a rubber grommet in the firewall you’ll be able to access easily if you take out the battery as it’s just down behind the battery tray. Feed the cable through there and it will appear in your passenger footwell. You may need to put a slice in the grommet to feed the cable through, I can’t rightly remember
Mouse
Post by Mouse » Fri May 08, 2020 11:32 pm
ah, excellent, thanks I will look into that tomorow
brownetara
Post by brownetara » Sun May 17, 2020 2:47 am
Rush2k wrote:
Sun Mar 20, 2016 5:37 pm
Nice design I'm thinking of a flip down single but may have to adapt the idea to incorporate a double as well.
I know it’s been a while since this post but wondering if you went ahead with the flip down bed, thinking of something similar.
Hardknocks
Post by Hardknocks » Mon May 18, 2020 9:35 pm
Tidy looking work sir. I didn't see, but have you figured a smart way to secure bikes?
aerobic247
Post by aerobic247 » Tue May 19, 2020 9:50 am
Hardknocks wrote:Tidy looking work sir. I didn't see, but have you figured a smart way to secure bikes?
Yes I used these Rockmounts Image
aerobic247
Post by aerobic247 » Tue May 19, 2020 9:55 am
Added a bonnet bra a new bumper and after market headlights Image
Hardknocks
Post by Hardknocks » Tue May 19, 2020 10:20 am
Rock mounts look the dogs nuts. Nice work!
guerillamahn
Post by guerillamahn » Thu May 28, 2020 10:27 am
love the rockmounts! Very nice build - as much as I like the rockmounts and generally feel like pulling the front wheel being quite a logical way to transport in vehicle - I like the idea of sometimes being able to just "toss in" my bike with a strap or two thought out and driving. I hope I can sort out a solution for this in a maxi with the 2nd row of seats in it - but anyway that is my plan at least - but yeah great thread, thanks for keeping it updated, lots to learn!
AleksanderRH
Post by AleksanderRH » Wed Jun 10, 2020 7:34 pm
Great thread! Thanks a lot for inspiration. Going to do much of the same as you. 8)
shameus
Post by shameus » Fri Jul 10, 2020 12:03 am
A question for those of you using your Caddy for sleeping in... is a roof vent necessary/worth putting in? Used mine for camping for the first time and found it a bit stuffy even with the front windows cracked (as much as was safe seeing it was a public area). Does a roof vent eliminate the need to have the windows cracked or do you still need to? Also, is there such a thing as a nice looking roof vent as I don't want to ruin the look of the van?!
Papa Bear
Post by Papa Bear » Fri Jul 10, 2020 9:02 am
@shameus, there are rear door stand offs you can get to allow fresh air, door still locks. Or window vents that keep it secure.
Black
Marmite lover!!!
VCDS
