Wingback Gti's, R32 then upgraded R36 power and 4 motion for my pure grey
hef355
Re: Wingback Gti's, R32 then upgraded R36 power and 4 motion for my pure grey
Post by hef355 » Thu May 07, 2020 10:42 am
james400 wrote:That's much better mate will be much easier is that inline with the new chassis legs?
Thanks James mate, yes buddy it is. Always wanted to extend the inner wheel arches in any case as the 10” rims were such a tight fit. Hoping there will be enough room for everything in there with a little luckImageImage
Beaker2135
Post by Beaker2135 » Thu May 07, 2020 9:45 pm
Really nice work, hope you can get everything in there it will look sweet
hef355
Post by hef355 » Thu May 07, 2020 9:52 pm
Cheers Steve! It’s coming along now, bit more welding done on passenger side arch and started on the driver side today ...Image
Pepsi
Post by Pepsi » Fri May 08, 2020 12:12 am
This is going to be awesome once done. A great way to get through the lockdown.
Hope you and your wife are well hef in these mad times.
hef355
Post by hef355 » Fri May 08, 2020 12:29 am
Thanks Pepsi mate! We’re ok thankfully buddy and hope you and the family are ok my friend
Pepsi
Post by Pepsi » Fri May 08, 2020 12:32 am
We are well thank you.
brooneye
Post by brooneye » Fri May 08, 2020 7:02 am
Wow, there’s some work gone into this big fella. Can’t wait to see it finished and make sure there’s plenty of pictures
Sean1066
Post by Sean1066 » Fri May 08, 2020 8:00 am
Nice and neat work there buddy.
My build thread
Giddy
Post by Giddy » Fri May 08, 2020 9:10 am
Good progress Hef! This is going to be a beast when finished 8)
Instagram: @giddywagen
hef355
Post by hef355 » Fri May 08, 2020 10:24 am
@brooneye
@Sean1066
@Giddy
Thanks guys im happy with progress so far, hoping to get to the workshop again today and hope the drivers side arch can be finished. Keep y’all posted
hef355
Post by hef355 » Fri May 08, 2020 6:50 pm
Other side under way! Hope my rear 10” rims will fit with the new H&R shocks! Should do as the inner arches are 70mm wider, tight squeeze ImageImage
JNWElec
Post by JNWElec » Sun May 10, 2020 1:06 pm
What a van!! Everything is so nicely done, what wheels are you running they are stunning
hef355
Post by hef355 » Sun May 10, 2020 1:41 pm
Thank you mate. Wheels are OEMS ifgtr 20” staggered. 10j rear 8.5j front both ET 45
JNWElec
Post by JNWElec » Sun May 10, 2020 1:44 pm
Thank you
hef355
Post by hef355 » Sun May 10, 2020 10:50 pm
So bit more done today! Rear 4 motion running gear cleaned up and alloy subframe fitted ready now for fitting. More welding done and extending strips cut and wheel arch trimmed ready for tacking and welding. Happy to have been able to minimise cutting, keep my original caddy floor and a degree of the van’s original structure in tact.
Sent from my iPhone using TapatalkImage
