Wingback Gti's, R32 then upgraded R36 power and 4 motion for my pure grey
hef355
Re: Wingback Gti's, R32 then upgraded R36 power and 4 motion for my pure grey
Post by hef355 » Tue May 12, 2020 10:08 am
Ahhh nice idea that matey as an alternative plan B, what’s the ride like on them I wonder? Keep up the great work James bud
james400
Post by james400 » Tue May 12, 2020 10:14 am
It's ok for moving around should be any day for the new ones comming tho they was just waiting on the springs to come in
hef355
Post by hef355 » Tue May 12, 2020 11:34 am
I’ll be sure now to keep up with these new shocks and all other developments from now on your thread lol!
hef355
Post by hef355 » Wed May 13, 2020 11:34 pm
Bit of an update today on the 4 motion!
So subframe bolted up and reassured on how its sitting without shocks at mo. Also enough room within the arch for my shocks. Bit more welding done and stainless sheets coming tomorrow so will make mock tank as pattern. Slowly but surelyImage
Sent from my iPhone using TapatalkImage
Pepsi
Post by Pepsi » Thu May 14, 2020 2:12 am
Looking amazing hef bet you cant wait to get it on the road. A d a great way to pass this time.
james400
Post by james400 » Thu May 14, 2020 7:34 am
Comming along well mate what's you plans with the suspension are you going all in one or separate spring and shock?
hef355
Post by hef355 » Thu May 14, 2020 8:39 am
@Pepsi thank you my friend slowly but surely coming along! Glad you’re all ok
hef355
Post by hef355 » Thu May 14, 2020 8:58 am
@James400
Ye think so for now J mate, got plenty of room between inner arch and wheel for shocker and it sits fine on the H&R old springs for now till my KW come!
Bloody 316 sheets not in now till Tuesday so making a tank this weekend is out typical
dan@biali
Post by dan@biali » Fri May 15, 2020 6:49 pm
@hef355
Was thinking about your issue with those front arms you posted about on james400's build thread. Just spitballing some ideas but could you make new arms instead of modifying the originals? They're only pressed steel so if you used some cdc engineering grade plate and tube you could make something relatively simple thats as strong so you can also use stock sized front bushes.
I doodled something on the computer and hopefully it will convey what I'm talking about and maybe others with more engineering knowledge can tell us why its a stupid idea :lol:
hef355
Post by hef355 » Fri May 15, 2020 8:18 pm
@dan@biali
Wow Dan you are a wizz kid on that PC for sure! Yes it has crossed my mind to make a new bracket buddy but one that I can adjust so I can centralise my wheel perfectly. A bracket like you’ve drawn but tubular like a thick drop link so I can adjust it. Am I overthinking this or is there any merit in what im thinking lol??
Offered the RS3 exhaust up today too and a mock up tank was made out of the old A3 Audi tank. Hopefully my 316 sheets come on Tuesday and I can make a tank at my mates workshop where he has a sheet bender!
Thanks Dan, your help, and everyone else’s is very appreciatedImageImage
Mock tank chopped down with a special cutting tool ... chain saw lolImage
dan@biali
Post by dan@biali » Fri May 15, 2020 8:30 pm
I did toy with the idea of doing a tubular version with an adjustable section like a tie rod. I’ll have another doodle at some point as it’s good practice for me!
dan@biali
Post by dan@biali » Fri May 15, 2020 10:34 pm
Something a bit like this where you have opposing threads on the threaded portion - the centre 'nut' is fixed and the 2 either end are lock nuts
hef355
Post by hef355 » Fri May 15, 2020 10:50 pm
Thats exactly what I mean Dan ... just think it would be useful to have an adjusting arm! Thanks matey, i’ll see what we can muster up next week.
james400
Post by james400 » Sat May 16, 2020 11:54 am
@dan@biali that looks a good idea mate will have to have a look next week to see if it can be done @hef355 looking good mate
hef355
Post by hef355 » Sat May 16, 2020 12:26 pm
@james400
Cheers buddy, cant wait to see yours on the road shortly. Mine will be a good good while after yours before it hits the tarmak J
