Caddy rear seats
stevesussex11
Caddy rear seats
Post by stevesussex11 »
Hi
Just joined the group
Im getting a caddy or caddy maxi in the next 2 weeks ex britisg gas 1 from the auction
And wanted to get seats in the back
Anyone help with people that can do it im in brighton area
Many thanks
GYCADDY
Re: Caddy rear seats
Post by GYCADDY »
Hi,
I had rear fiat Doblo seats fitted for about £1200 at fast fit nationwide in West Bromwich.
they did a good job, takes a full day but worth the drive. I would show you a pic but new to the forum and not sure how to add a pic.
Limbo118118
Post by Limbo118118 »
Seen a few setups on ebay fella
Insta : Limbo118118
menz21
Post by menz21 »
I purchased a set of caddy life seats off eBay from Germany.
Got them new from a company that did rear access modifications.
I purchased the sub frame part separately but the hardest bit was sorting out the seat belts.
c@ddyme
Post by c@ddyme »
Hi is it quite easy to fit these then? Does the fittings bolt in looking at this option as im thinking i may be able to fit myself... how did yours go???
chunk22393
Post by chunk22393 »
Think there’s about more to just bolting them in bud, from what I’ve seen you have to remove a welded panel from the floor and weld in another section with the seat mounts in place!
Jono1
Post by Jono1 »
I’ve put touran rears in mine. Easily removable if you still need the van space.
There’s quite a few threads on them on here 👍
lscott141
Post by lscott141 »
@c@ddyme
Look up a boy called Dan Chambers on Youtube. He has a Caddy restoration series and he shows how to fit rear seats. Defo not a bolt on job.
