Headlight retrofit
Barrington
Headlight retrofit
Post by Barrington » Sun Dec 27, 2020 9:25 pm
Hi all,
Does anyone know off anywhere to get my headlights retrofitted from halogen to bi xenon. I’m in the northwest of England near Manchester
hef355
Re: Headlight retrofit
Post by hef355 » Mon Dec 28, 2020 12:58 am
I’ve converted mine buddy to genuine Touran bi xenon lights. Expensive but superb! Kufatec do a kit for thisImage
DeanWhit
Post by DeanWhit » Mon Dec 28, 2020 3:31 pm
Vanquish customs in Huddersfield do different types of headlight builds. They're on Instagram or they have a website.
anoneamus
Post by anoneamus » Tue Dec 29, 2020 7:38 am
You will pay quite a bit extra to have it done for you. It's not that hard a job, once you have all of the pieces. I've made a guide here:
viewtopic.php?f=22&t=25064
I believe the only place in UK you should consider getting it done by is Hazzy Daze, as they are able to make up the wiring loom.
hef355
Headlight retrofit
Post by hef355 » Tue Dec 29, 2020 10:29 am
Totally agree with @anoneamus ... his link and guidance was invaluable to me when I fitted mine. The Kufatec instructions are not much good to be honest. These ate brilliant OEM lights though and highly recommended
anoneamus
Post by anoneamus » Tue Dec 29, 2020 1:01 pm
These ate brilliant OEM lights though and highly recommendedImage
Best lights ever! These are literally the pinnacle of lighting on the Caddy. The newer (Mk4, Mk5) lights are not as bright and don't 'steer' (lights follow steering to point on the road around bends). I'm not aware of any aftermarket lights that come anywhere close either. And they look cool. ;)
tonyhill
Post by tonyhill » Tue Dec 29, 2020 7:54 pm
I specced bi xenon lights on my mk4 from new, and they do come with the cornering function 👍
anoneamus
Post by anoneamus » Wed Dec 30, 2020 8:42 am
AFAIK, they don't have the sensors etc. necessary for this. They have static cornering lights, which is something different to the "bend" function (where the projector actually moves with the steering). Also, they are also 25W compared to the 35W of the Mk3 lights. In any case, you can confirm/disprove this by seeing if there is a "bend" light function in the "assistance" menu on the MFD. This function falls under "AFS" (there is also "ALS" for auto level setting). Hazzy Daze page for these specifically mentions: "Please note: Auto leveling/AFS is not available from factory on this model."
rbu_tuninq
Post by rbu_tuninq » Thu Jan 07, 2021 11:05 pm
Doing and projector retrofit to mk4 headlights now... with morimoto d2s 5gen .... from the standard h4 bulb.
Hope will turn out nice :)
rbu_tuninq
Post by rbu_tuninq » Thu Jan 07, 2021 11:07 pm
What year caddy are you after ?
Hi all,
caddy4mo
Post by caddy4mo » Wed Mar 17, 2021 1:24 pm
I've got these on my mk4. Quite happy wih the lighting, but might add a Lazer Linear 18 for next winter!
