Daddy's Caddy update September 2014
DADDY
Re: Daddy's Caddy update September 2014
Post by DADDY »
Thats the rear brake calaper and discs fitted. No special flexes or brackets required, standard flexes (unless you want to upgrade) and simply switch over the hand brake cable cams and cable guide bracket from the 2k brake calliper and assemble onto the R32 calliper. I took a few pics to help anyone else doing the same mod in future. Will at it as a how to on my build thread as soon as I get a minute.
Heres a few pics of the install.
dan@biali
Post by dan@biali »
Glad you got it sorted. Strange mine needed custom length flex lines though.
geezer
Post by geezer »
Nice, Bet it stops well now!!! :)
DADDY
Post by DADDY »
dan@biali wrote:Glad you got it sorted. Strange mine needed custom length flex lines though.
Yes Dan I wondered about that to. I ordered HEL standard 2k rears with carbon outer sheath to match the front, but once you change the cable locating brackets from R32 calliper to the original 2K bracket the flexible lines go to the exact same position as standard. I took as many pics as I could to help any one else doing the same mod in future, I will post up a how-to and it will hopefully all make sense. Thanks again for your help Dan.
DADDY
Post by DADDY »
geezer wrote:Nice, Bet it stops well now!!! :)
Still bedding the pads in, I will let you know in a day or two ;)
euan tdi
Post by euan tdi »
Just bought a set of Mk7 R brakes front & rear, just going to order hoses then find some time to fit them :D
2013 Highline 2.0 140, KW HLS kit, new set of Helios viewtopic.php?f=1&t=12710
SimonR
Post by SimonR »
Van looks very cool, well equipped and functional Daddy :)
Brakes look very capable too ! :D
the long one
Post by the long one »
noticed that you have bilstein shocks up front which ones are they?
nice colour !
