Stormtrooper caddy 4 build
Sag1
Re: Stormtrooper caddy 4 build
Post by Sag1 » Tue Sep 22, 2020 3:06 pm
Good work dude. Scratch came up really well!
2106 Caddy Life 1.4 TSI | Wheelchair Driver | My Instagram
Caddyluv
Post by Caddyluv » Tue Sep 22, 2020 3:34 pm
Yes bit of 2000 grit and rotary polisher only took 5 mins. Quite bad. But sorted.
Pepsi
Post by Pepsi » Tue Sep 22, 2020 6:29 pm
Is it really that easy ( I say easy) to remove deep scratches. I have a few on the side and a couple along the back of mine. Is there a certain point at which this method won't work?
Also could you reccomend a rotary polisher for a beginner. Looking to get into trying a proper polish and scratch removal.
Caddyluv
Post by Caddyluv » Tue Sep 22, 2020 6:56 pm
@pepsi
Well yeah there is a point... your go through the clear coat then your need to respray it. But if there light then yeah a bit of 2000 grit a little sanding pad and a bit of experience.
Rotary tend to cut quicker but honestly they can be a little dangerous in new hands so I would recommend a Vertool DA doesn’t cut as quick but does a good job. Your need the correct pads and compound..... it starts getting expensive ImageImage
https://rover.ebay.com/rover/0/0/0?mpre ... 4693030837
Caddyluv
Post by Caddyluv » Tue Sep 29, 2020 5:06 pm
Got a nail ImageImageImageImage
Caddyluv
Post by Caddyluv » Fri Oct 02, 2020 6:35 pm
So the vans back to normal today got a new tyre fitted. Would like to thank ATS in cheriton for driving the van into an upslope and ripping the bottom of the bumper along the concrete so after I was telling the guy to be careful and about the side skirts and it’s low...they clearly didn’t listen so £50 reduction on the tyre so it wasn’t to sad. I was just worried it could have cracked the custom bumper but thankfully all looks ok. But it was hammering it down so it was a quick look.
Caddyluv
Post by Caddyluv » Tue Oct 20, 2020 11:56 am
Little service today.
Also glow plugs. Had a engine management light pop up. It was plug 1. So replaced them all.
All done running smooth. Image
Azz03
Post by Azz03 » Tue Oct 20, 2020 12:36 pm
Caddyluv is your rear number plate plinth an edition 30 or have you custom made that? As it doesn’t look like a painted line
Caddyluv
Post by Caddyluv » Tue Oct 20, 2020 1:54 pm
@azz03. No mate it’s been custom made. Image
Then primed, preped and painted. Use thin pinstripe tape to do the black and white paint. Image
Azz03
Post by Azz03 » Tue Oct 20, 2020 2:20 pm
Caddyluv I did think you’d put a small rebate on the plinth to give the idea of the separate lip looks top notch mate. I have searched loads but they don’t do the edition30 rear plinth do they only the side strips?
Caddyluv
Post by Caddyluv » Tue Oct 20, 2020 4:34 pm
Yes mate. That’s why we made one, there isn’t one out there, Thank you I think it’s a nice touch.
Azz03
Post by Azz03 » Tue Oct 20, 2020 6:13 pm
Caddyluv you can’t beat the mods that are hand made as it’s unique cheers for the reply
james400
Post by james400 » Tue Oct 20, 2020 10:36 pm
Nice and fresh ready for the winter mate
Caddyluv
Post by Caddyluv » Wed Oct 21, 2020 8:06 am
Just needs a wash now. But with this weather you think what’s the point.
Caddyluv
Post by Caddyluv » Thu Oct 22, 2020 10:42 am
Vans so dirty needs a good clean. But doing these country lanes you think why bother.
