Caddy 4 wheel drive build
- james400
Re: Caddy 4 wheel drive build
Thanks mate been building it for the last 3years should be around the 800 when it's all mapped up
- james400
Striped down the old engine to see if I can find out what had gone on it and I think I found it lol
- torque777
That's definitely worn lol
Sent from my LYA-L29 using Tapatalk
- james400
Just abit never seen one like that befor lol
- james400
So thought i'ed up this as not done it for some time so where I am at now is the new engine is in and built up all the new suspension is on with the rs3 brakes on. I've had new tyre fitted to the wheel I've converted from hydraulic power steering to electric power steering and also pulled all the interior and Dash out and fitted aircon to it all going well this weekend should be the big start up on the new engine then the new Touran dash can go back in so I'm about 80% there now I've got my fabricator at rw developments building me my intercooler and rad pack what I should get back in a week or two then I'll finish off the little bits then its back down to him to do the boost pipes exhaust system and fuel tank as I now want to have the bottom of the van level and I can have the take built to a better spec than the one what is already fitted
- james400
Done abit more 2day got it running and put in the last bit of wiring for the aircon ready for next week to finish of the wiring inside
- james400
The first start up on the new engine https://youtu.be/-qBJtQ9Ngs8
good work!
amazing build !
- robblowen
That sounds dirty!!! (In a good way)
- B3NNB
Hi mate, you using a bit of heat on them nylon fuel lines to push the connectors in?james400 wrote:Abit more done made the new fuel pipes up and fitted then made the wiring loom for the tank and tested all good finished the suspension turrets and fitted new brembo pads and discs built it up and dropped it down drove it out to give it abit of a wash off lol still abit to go tho as I need to get the abs looms made longer and sort out the spring load as they are too soft so as you see it it is on its highest setting and the van it too low for me and that's with nothing in the back so will have to work that out but at least it's now moveable for the brakes are bled up and handbrake all connected up and works.
- james400
Yes mate abit just to soften it Upton get them in
- james400
So update on this alot has been done just not had the time to update this sorry so got it running now so the big rebuild can begin.i managed to get some silicon hose made for the engine just a cosmetic upgrades but looks nice also new intercooler new rad and aircon condenser I've also fitted a newer front end what I think looks loads better afew bits more to do but not far off lol
- james400
So now 90% of the wiring is done inside I can now build up the inside fitted the Touran dash in my opinion it looks well nicer than the caddy dash also just for the time being I got my mate at rw developments to build me up a race tank go put it the rear this is because I am going to get him to build me a flush fit tank underneath later on in the year
