Caddy 4 wheel drive build
james400
Re: Caddy 4 wheel drive build
Post by james400 » Wed May 13, 2020 1:37 pm
Lister79
Post by Lister79 » Wed May 13, 2020 5:16 pm
Looking good mate. Nice work on the arch liners, and love the fuel cap.
2014 Toffee Brown 1.6TDi
james400
Post by james400 » Wed May 13, 2020 5:49 pm
Thanks mate alot more to do on the flap but it's getting there
hef355
Post by hef355 » Thu May 14, 2020 1:44 pm
@james400
Love that R8 flap J! You bonding that in buddy or doing ant welding as its a bloody big panel that to distort with heat isn’t bud! Be interesting to see how you route the filler as its bloody tight to get the loop in to the standard flap! Headaches r us aye buddy hahaaa
james400
Post by james400 » Thu May 14, 2020 3:43 pm
Hi mate I'm going to 3d print the brakets then bond it on the inner quarter with some windscreen Bonding to be honest it will be pretty straightforward it will just mirror the other side and the inner panel will
hef355
Post by hef355 » Thu May 14, 2020 4:14 pm
Ahh that sounds great J buddy! This van is going to be superb buddy! Wish i could be your apprentice ... can just about spell 3D printer let alone use one haha
james400
Post by james400 » Thu May 14, 2020 4:53 pm
You are mate look at your van it 4wd now lol you sorted anything with you propshaft yet?
hef355
Post by hef355 » Thu May 14, 2020 5:10 pm
Not yet buddy and will look at that tomorrow now seeing as my sheets aren’t in to start on the tank!
Im not sure which way we should extend the lower support arms that the short drop links fit onto. Im thinking of cutting the end off where the rubber bush is and slicing a pipe down the centre and slotting it onto the lower bracket and welding it on then thread one end where it goes into the original Caddy bracket where the leaf spring used to attach to making it adjustable enabling md to centralise the wheel perfectly!
This bracket ...Image
Needs extending about 8 inches and i’d rather extend that plate to attach to the original Caddy bracket rather than weld a new one really. Be far stronger attaching to where the leaf use to be. What du think?
james400
Post by james400 » Thu May 14, 2020 6:16 pm
Problem with that is it want work the way your thinking I've been down that root when I was doing mine it puts more pressure on the other bushes and when you come to track it up the adjustment is a nightmare I did see one cut the arm and weld it up so it's a straight arm but in my my opinion that was abit of a Bodge is it much out? If it's only afew mill you can get adjust bushes for them ones
james400
Post by james400 » Thu May 14, 2020 6:24 pm
@hef355 This is what one was done like mate
https://www.forum.caddy2k.com/viewtopic ... 7&start=30
hef355
Post by hef355 » Thu May 14, 2020 6:34 pm
@james400
Ye ... the end of the plate is about 200mm from the original bracket ... agree thats the easiest way of doing it J just make and weld new brackets on to the chassis but I think i’d rather extend those plate approx 8” and have them fix onto the original brackets J. How have you done yours buddy? Welded new brackets like this?
Sent from my iPhone using TapatalkImage
james400
Post by james400 » Thu May 14, 2020 7:32 pm
No mate I welded the donor vehicle plates in Image
hef355
Post by hef355 » Thu May 14, 2020 8:39 pm
Ahhhh yes of course buddy ... but different to mine! When du think you’ll be on the road J
james400
Post by james400 » Thu May 14, 2020 9:51 pm
Afew weeks I would say mate
hef355
Post by hef355 » Thu May 14, 2020 11:44 pm
Cant wait to see it done my friend, will be epic
