Toffee delights
Jeffers76
Re: Toffee delights
Post by Jeffers76 » Wed Mar 04, 2020 3:30 pm
Cheers buddy will take that on board when i start mine, have you then put caps over the screw or just used black ones sorry for all the questions
just wanna make sure am 100% right in my head before i make a start :D
Lister79
Toffee delights
Post by Lister79 » Wed Mar 04, 2020 4:14 pm
No mate I’ve countersunk all the holes and once fitted in place I screwed the screws in so they are a mm or so from the board then using a pick I pull the carpet over the screw heads, then tighten the screws fully and play with the carpet so the cut blends in. It’s a bit of a faff but makes all the fixings completely invisible, which makes it so much neater without any screws visible.
Never bother about asking questions mate, that’s how we all learn at the end of the day.
2014 Toffee Brown 1.6TDi
Jeffers76
Re: Toffee delights
Post by Jeffers76 » Wed Mar 04, 2020 11:33 pm
Yea fair play mate that's taken some time but as you say it is gotta be worth it yours looks sweet, so you ain't used any of the oem fixings but have put screws in and then used the carpet to hide, yea do like that, an as for questions just didn't want to pester but as you say that's how we learn and progress :)
Lister79
Re: Toffee delights
Post by Lister79 » Thu Mar 05, 2020 3:53 am
Yeah that’s right. No original fixings but used hidden trim clips (from Harrison trim supplies) in their place then additional screws to give extra support, all hidden with the grey carpet.
Jeffers76
Re: Toffee delights
Post by Jeffers76 » Thu Mar 05, 2020 10:26 am
Awesome mate cheers for tha, off to get the timber :D :D
Caddyluv
Re: Toffee delights
Post by Caddyluv » Thu Mar 05, 2020 5:09 pm
As ever looking good. I was going to do this fibre optic roof. Had a few ideas but then the van had to kinda change for work so it wouldn’t have worked. But I like it. Well done.
Lister79
Re: Toffee delights
Post by Lister79 » Fri Mar 06, 2020 4:37 am
Cheers Ryan
Iain88
Re: Toffee delights
Post by Iain88 » Tue Mar 10, 2020 10:23 am
Just read this from start to finish cracking van 👌 credit to you
Lister79
Re: Toffee delights
Post by Lister79 » Tue Mar 10, 2020 5:24 pm
Thanks mate, much appreciated.
Lister79
Re: Toffee delights
Post by Lister79 » Tue Mar 10, 2020 7:26 pm
Got my replacement rear axle finished off and ready to be taken to the powder coaters. Antiroll bar relocated using 5mm x 50mm Carbon steel flat bar (in prep for when the van goes onto air suspension) and permanent spring saddles (from retrofication) welded on. Hopefully get it dropped off at the powder coaters this week.
Old pieces removed
New parts welded on
Ready for powder coating
R22LRM
Re: Toffee delights
Post by R22LRM » Thu Mar 12, 2020 9:11 am
Alright Chris, some big mods in development will make this top of the pops pal
Which arch kit did you use the genuine vw or the van style, toying with doing mine as I have s5 blades on and yours looks awesome.
R22LRM
Mk5 Tfsi powered
Lister79
Re: Toffee delights
Post by Lister79 » Thu Mar 12, 2020 2:34 pm
Hi mate I’ve used the van style kit however if I’m honest I will be looking to fit the genuine kit in the future (once I’ve completed the other work I have planned) as the genuine kit is slightly deeper which I think looks better, but it’s only a minor difference.
Msoll90
Re: Toffee delights
Post by Msoll90 » Wed Mar 18, 2020 8:30 pm
@lister79 I have just read this full thread got to say you are doing a top job the attention to detail is 2nd to none 👍 I have just fitted the mk4 tail lights on my van luckily you have put a pic of the wiring on which helped me out a lot thanks keep up the good work
Lister79
Re: Toffee delights
Post by Lister79 » Thu Mar 19, 2020 9:24 am
Nice one mate, thanks for taking the time to read my thread.
The MK4 lights make a massive difference, just don’t forget to have them coded in right @doc will be able to sort for you or potentially point you towards someone local.
Msoll90
Re: Toffee delights
Post by Msoll90 » Sat Mar 21, 2020 5:24 pm
Yes the mk 4 lights make a massive difference and they do need coding but I'm waiting to get highline clocks so I might as well wait and get everything coded in one sitting but thanks I will get in touch with doc and get recommendations 👍👍
