My EX BG VR6 3.2 build
- C Chis
Re: My EX BG Maxi Caddy build
You're making good progress!
Will be good to see and hear it running!
I’ve said it before Sean, you are a braver man than I. The picture above proves my point!
Looking good so far mate. Keep up the good work
- Guy94
Keep the updates coming buddy, I love seeing them. Awesome to see that great big pig right at home now in your engine bay! Good stuff mate
- Lister79
Good progress Sean.
- Sean1066
Thanks guys for all your kind words and encouragement.
Manage to get a lot of the wiring into the ecu connector today. Had to change all the pin on the caddy ecu wires to the Audi pin as they are slightly different.
Just the lambdas, air mass and 2 fuses to put in the ecu.
Then take out the unused caddy wiring.
Hopefully I will get that done Wednesday.
That’s the plan
That’s the plan
- Sean1066
Well you make a plan then someone always puts a spanner in the works.
Not been able to work on the caddy that much this week as work has been mental. But managed to get so much needed time on it this afternoon.
Got the new to me subframe in.
With new stretch bolts.
Got the exhaust bolted up with the 4 new lambda bolted in
And then got some more of the wiring done
Next on the wiring is the fuse box wiring and still got to remove the unused caddy wiring
- 11ATL
was it cut the blue wire or cut the red wire?
That looks both great & frightening at the same time.
Caddy Maxi C20 1.6 TDi 102PS
- Sean1066
@11ATL
Most of the wiring is done now just got to put two relays in, run wires for two fuses and then tape it all up and the wiring is done.
Should be back on the ground this week all being well
- 11ATL
Sounds good, how big is the instruction manual for this, take it's a tad bigger than an IKEA Wardrobe instructions?Sean1066 wrote:@11ATL
Got a date for first firing up, you going to video that for us all?
- Sean1066
Just a little up date the down pipe is now connected to the exhaust.
All the wiring is getting taped up.
Hopefully I will have it running by Saturday night
Nice one mate. It’s getting there!!
- hef355
Great progress Sean! Bet you cant wait to hear it growl! Well done so far
- Sean1066
@peter
thanks buddy hopefully I will be running this weekend
@hef
Thanks buddy. Yes I’m so looking forward to hearing it growl
@hef
- Sean1066
Been at it again today.
Got the new cluster in (with blue needles)
Tried to see if the engine would turn over today and it did.
So now the next step is to sort out some of the errors that have came up with a scan.
Sorted out some of them already.
- Handyandy
It's definitely coming together now nice tidy job
Weekends nearly hear so hopefully all going to plan
