Mk IV Caddy 2.0 102 Startline BMT
ViralEye
Re: Mk IV Caddy 2.0 102 Startline BMT
Post by ViralEye » Wed Sep 30, 2020 8:19 pm
Caddys like to make pockets empty!! But, with everything I've spent on mine, when I add it all up, it isn't actually that much
ViralEye
Post by ViralEye » Fri Oct 16, 2020 11:13 am
And so it begins.... With me slicing my fingers several times peeling back the sound deadening Image
Now the drill is on charge ready to drill out the spot weldsImageImageImage
ViralEye
Post by ViralEye » Fri Oct 16, 2020 3:12 pm
Very very slow progress as it turns out when I'm drilling the very centre of the spot weld, it's actually to the right or left of it ImageImageImage
ViralEye
Post by ViralEye » Fri Oct 16, 2020 5:11 pm
And I end today here
New spot weld bits now on order as the other 2 are blunt Image
I know this is the hardest bit too do, but holy jebus it's a pain!Image
Caddy46
Post by Caddy46 » Fri Oct 16, 2020 6:33 pm
Good effort dude! Right tools for the job spring to mind hahaha I’m kidding!
ViralEye
Post by ViralEye » Fri Oct 16, 2020 6:34 pm
The spot welds have been stupid... More like a blob weld, and it might not be in the actual location of the weld.... Getting there slowly though
Caddy46
Post by Caddy46 » Fri Oct 16, 2020 6:36 pm
Robot welds that’s why! What seats will you be using in two minds whether to add seats at a later stage, although I’ve bought it for fishing and bikes so need the room!
ViralEye
Post by ViralEye » Fri Oct 16, 2020 6:38 pm
More like apprectice welds
Got some brand new caddy life 2 + 1 seats to go in - they fold forwards then unclip out
Caddy46
Post by Caddy46 » Fri Oct 16, 2020 6:40 pm
ViralEye wrote:More like apprectice welds Image
Got some brand new caddy life 2 + 1 seats to go in - 5hey fold forwards then unclip out
Sort of like transport Kombi seats then unclip jobby and out, what sort of fixings do you need? Tps?
ViralEye
Post by ViralEye » Fri Oct 16, 2020 6:44 pm
There is a front plate that needs putting in, but it's only a support bracket so sikaflex and a load of rivets(or you can weld in if you really want to) is enough
Then it's just 4 brackets that need drilling through and bolting from underneath
ViralEye
Post by ViralEye » Fri Oct 16, 2020 6:49 pm
Here's some pictures I was sent from another member which should make a bit of sense
ViralEye
Post by ViralEye » Sat Oct 17, 2020 2:06 pm
Well the panel is off, all exposed metal work spray painted to stop any rust and leave now for another weekend. Test fitted the single seat to see how it works look tooImageImageImageImage
ViralEye
Post by ViralEye » Tue Oct 20, 2020 8:20 pm
I made a small mistake... and now I've got diesel on the floor Infront of my house... So I have roughly put the seats in place and a good friend of mine is going to repair the tank and fix the seats into place whilst he's at it ImageImageImageImageImageImage
Pritchard182
Post by Pritchard182 » Wed Oct 21, 2020 10:14 am
Hi mate van is stunning. Im looking at getting ting rs3 seats same as the s3 ones i think. Did you fit them without touran bases after? And i just want the airbag to work not heated bits is this posable? Without a warning light being on?
ViralEye
Post by ViralEye » Wed Oct 21, 2020 10:48 am
I fitted the seats straight to the bases, just had to drill some holes and some nuts and bolts. The seats are like mm wider than the rails so just pushed them in so the holes alligned which is easy enough to do
The air bag yes you can just get a connection, Stan the man sorted mine for me as an air bag loom, and then separate heated seat loom
