Mk IV Caddy 2.0 102 Startline BMT
vizidomar
Re: Mk IV Caddy 2.0 102 Startline BMT
Post by vizidomar » Sun Sep 08, 2019 6:11 pm
Hi ViralEye,
I need your help on seat heating!!
Which pin of the bcm did you put your wire in?
I connected mine in connector B (white), pin 21, as I did in my previous, 2011 caddy,
but it's not working. In fact, I killed something, I have no blower motor since..
TIA,
Attila
ViralEye
Post by ViralEye » Sun Sep 08, 2019 7:01 pm
vizidomar wrote:Hi ViralEye,
TIA,
Attila
It was the middle B set of plugs on the BCM, then number 21 wire... Hope that makes sense
vizidomar
Post by vizidomar » Sun Sep 15, 2019 6:07 am
Yes, it makes.
Thanks, mate!
Millencolin
Post by Millencolin » Tue Sep 17, 2019 7:23 am
Wow sucks that cruise control does not come standard, here in oz pretty sure its standard on al swb and maxi,
i know what you mean about cruise control and long drives i changed cars just for the cruise control my old nissan could not retrofit only aftermarket but its not the same...
Great mods keep em coming.
Golf mk4 1.6l 2002 (Sold)
Transporter T4 2.5Tdi 2001 (Sold)
Jetta 2.0Tdi 2010 (Sold)
Passat CC 2010 2.0Tdi
Caddy 2.0Tdi 2017
ViralEye
Post by ViralEye » Tue Sep 17, 2019 10:59 pm
Millencolin wrote:Wow sucks that cruise control does not come standard, here in oz pretty sure its standard on al swb and maxi,
Cruise control has come in so handy - had a 250 mile each way journey to make after I installed CC and it made the journey so much easier. And now I can also see what my average MPG is Image
TomRad
Engine size/power: 2.0 CNG (107bhp)
Post by TomRad » Sat Oct 12, 2019 4:03 pm
Hi mate,
I've also got a startline 102 16 reg, how do you see what speed your cruise is set to on the startline display module?
I'm thinking off adding the cruise stalks to my caddy.
Cheers!
ViralEye
Post by ViralEye » Tue Oct 15, 2019 11:23 pm
You can't, you've got to have cruise stalks fitted then activate via an obd device. The stalks are around £60 and generally easy to fit
ViralEye
Post by ViralEye » Sun Oct 27, 2019 8:01 pm
Not bought anything for the Caddy recently, so thought it was about time I treated her ImageImage
ViralEye
Post by ViralEye » Thu Oct 31, 2019 7:54 pm
And they've arrived!!! Can't wait to fit them to see what a difference they makeImageImage
ViralEye
Post by ViralEye » Thu Nov 07, 2019 9:58 pm
Well I installed them, then the next day took them out and back to halogen - very poor lights!
r1lea
Post by r1lea » Thu Nov 07, 2019 10:37 pm
I bought a set when I bought my caddy
The light colour was great but the beam pattern and strength was very poor so I went for a pair of oem bi xenons
ViralEye
Post by ViralEye » Thu Nov 07, 2019 10:38 pm
I was honestly shocked at how poor they was! Would love bi xenon, but my god they're expensive!
ViralEye
Post by ViralEye » Mon Jan 06, 2020 5:16 pm
Another delivery of some sound deadening and some insulation.....
Plan is to get the seats out, pull the carpet up and then sound deaden and insulate all the floor including the bit behind the seats and then get the carpet liner from VW for behind the seats. Should make it even quieter and warmer ImageImage
ViralEye
Post by ViralEye » Mon Jan 06, 2020 5:17 pm
Oh and another item picked up so I can cut out the slot for my puddle lights ImageImage
ViralEye
Post by ViralEye » Sat Jan 11, 2020 5:44 pm
I had the most stupid idea, in taking up the front carpet and deciding to sound deaden and foam insulate the floor and I can tell you it was an absolute b***h of a job!
Next job is to get the carpet for the floor behind the front seats and then the cab is all done
Now time for a beer!
