Doc's 2013 Caddy
tonyhill
Re: Doc's 2013 Caddy
Post by tonyhill » Mon Aug 19, 2019 3:14 pm
BradleyB wrote:
Mon Aug 19, 2019 8:57 am
U are getting better mpg than my diesel
Vw are a joke
I stuck my cruise on at 50mph on the motorway, with a fully loaded van I was getting 61mpg.....I was quite happy with that.
BradleyB
Post by BradleyB » Mon Aug 19, 2019 7:29 pm
I’m on 9 thousand miles not due 1st service yet
It’s dsg
My van is empty aswell
BradleyB
Post by BradleyB » Sun Aug 25, 2019 10:11 pm
Just shows that you should buy yours vans from doc and not vw
JONDRA
Post by JONDRA » Sun Aug 25, 2019 10:42 pm
Wow, some very impressive work done here, I have no clue about all the coding stuff for changing/adding parts, best I do some reading! Love the Tiguan instruments, that’s going on Rooney’s Xmas 2022 wish list!
Post by Doc » Sat Mar 07, 2020 10:34 am
Been a while since I've done anything other than maintenance and refueling my caddy.
I recently installed a set of Audison APK165P speakers.
After hearing how they sounded in @r1lea van, I knew it was inevitable.
Cost me £156 for the speakers from Amazon and £17.99 for MDF adaptors from eBay.
The adaptors I bought were listed as compatible with Caddy 2004+ but they needed to be drilled.
MDF isn't the toughest material to drill so no big deal really, apart from me drilling them wrong the first time around as I put the speaker and adaptor back to back without first checking it was symmetrical.
I used M6 rivnuts in the door panel in place of the original pop rivets.
I soldered onto the original factory speaker plug to avoid having to add another plug & socket.
For the tweeters, I tapped into the A-pillar socket wiring.
Sounds great now, much better than standard.
Next up will be a Audison active Sub under the seat to fill in the bass.
ed1119
Post by ed1119 » Sat Mar 07, 2020 10:56 am
Great work Doc.
Jeffers76
Post by Jeffers76 » Sat Mar 07, 2020 2:17 pm
They look really good, currently looking at speaker options
r1lea
Post by r1lea » Sat Mar 07, 2020 4:12 pm
Awesome speakers
Can’t wait to hear the Audison sub
Glen G
Post by Glen G » Sat Mar 07, 2020 4:45 pm
Nice work mate neat job too
Post by Doc » Sat Mar 07, 2020 4:50 pm
Cheers guys, I'm really impressed with these speakers.
I punched the back of the rivets out to indent the panel slightly so the adaptors don't sit on top of the rivnuts, turned out ok. Not really that bothered that I drilled the extra holes, the MDF is dead solid.
michealcaddy
Post by michealcaddy » Sun Mar 08, 2020 3:05 pm
Stunning van Doc! Do the mk4 rear lights fit straight on to the mk3 or is there a bit of fiddling involved
Post by Doc » Sun Mar 08, 2020 5:40 pm
Cheers @michealcaddy
Check out the how-to topic I did on the rear light retrofit. There is some moving of wires in the plug and some recoding required.
Brian383
Post by Brian383 » Mon Mar 09, 2020 12:31 am
Unreal thread bud. Your deff the man I need to speak to about wiring my bwj running gear into my 2011 1.6tdi? Can't wait to be able to have excess to the rest of the forum for some more useful info
krzychur1
Post by krzychur1 » Thu Apr 16, 2020 11:46 pm
Very nice and tidy under the hood, whats the power figures?
Post by Doc » Fri Apr 17, 2020 3:37 am
Thank you, tidy was the aim.
It's not been on a dynamometer, my tuner 300bhp is going on past experience with boost levels on these engines.
