Swan’s caddy build
Papa Bear
Re: Swan’s caddy build
Post by Papa Bear » Fri May 01, 2020 2:11 pm
Guns on eezibleed, that’s it
Black
Marmite lover!!!
Post by the swan fiend » Fri May 01, 2020 2:22 pm
Just waiting in the queue at Halfords to get one now
Barbel330
Post by Barbel330 » Fri May 01, 2020 3:22 pm
Calipers look good mate. It’s a pet hate of mine when I see people have painted over the brake pads, rubber seals, clips etc. Looks so much more professional the way you’ve done it.
Instagram: @y_5cuf
Post by the swan fiend » Fri May 01, 2020 3:37 pm
Cheers Stu. That means a lot coming from you mate.....you’re a master of your craft!
I’m glad I took them off, more work but it’s a neater job I’m sure, and I do try to do things the best I can. Plus, I spotted my blown dust seal too.
James01
Post by James01 » Fri May 01, 2020 5:04 pm
Brakes look good but the rusty discs let it down now! Not fancy black hammerite on the rusty bit?
Sent from my SM-A505FN using Tapatalk
Post by the swan fiend » Fri May 01, 2020 6:21 pm
You know what mate? I never even thought of it! But you’re right, and I have some of that in my shed
Post by Stedlocks » Sat May 02, 2020 10:52 am
I've just ordered that gunsonskit....you'll have to let me know how you get on with it....
Looking really good mate......youllneed tower brush the discs now though...etc! :lol:
Papa Bear
Post by Papa Bear » Sat May 02, 2020 12:27 pm
Only time the gunson kit didn’t work for me was a Saab 9000 with a dodgy abs valve, I think you will find it very useful to use on your own.
Black
Marmite lover!!!
Post by the swan fiend » Sat May 02, 2020 1:20 pm
I’m not having much joy with it mate. Rigged it up to a tyre, and got very little out on the rear. Increased the pressure (like an idiot) and I emptied the reservoir that came with the kit
So I reckon it’s full of air now. I’ve moved onto the fronts, and when I pressurise and open the bleed nipple, I’m getting nothing.
I’ve messed this up quite bad I think. Starting to worry now
Papa Bear
Post by Papa Bear » Sat May 02, 2020 1:31 pm
Emptied the reservoir? As in ran out of fluid?
Just fill it and start again, will push the air out. Doesn’t need much pressure, won’t come shooting out, you don’t want it coming out too quick or it can get more bubbles.
Best to start with wheel furthest away from reservoir and work forward. The one you did first running clear?
Black
Marmite lover!!!
Post by the swan fiend » Sat May 02, 2020 1:35 pm
Yes mate, I don’t know weather the tank in the actual van emptied as well. I’m getting quite a lot of air coming through the drivers side caliper so I think it may be ok once that’s cleared.
I’m worried about needing to bleed ABS and clutch as I don’t know how. I’ll cross that bridge if I need to.
Thanks for your help and advice mate
Yes, started near side rear. Got that ok I think
Papa Bear
Post by Papa Bear » Sat May 02, 2020 1:39 pm
Eezibleed can be used for clutches too.
Just googled caddy abs bleeding and seems you have to do it in VCDS
someone here must have some experience though
Black
Marmite lover!!!
Post by the swan fiend » Sat May 02, 2020 1:40 pm
Yes, I though that would be the case. It’ll be going to the garage if it needs doing
Post by Doc » Sat May 02, 2020 2:27 pm
If you've got air into the ABS then it will need to be run on the bleed cycle to clear it properly.
Don't pump the pedal if the reservoir is empty, that may damage the seals.
What you might find works best is to pump some through with the pedal, just make sure not to run dry.
I've done it on my own with a torque wrench between the pedal and the seat to keep it pressed. Then release the pressure at the caliper.
Slow but possible.
