Page 27 of 56
Re: Swan’s caddy build
Posted: Wed Nov 25, 2020 10:06 am
by the swan fiend
Cheers C Chis, it’ll keep you busy for an hour or two anyway
@Ranger D I have a bulb error light anyway mate as I have LED DRL and tail light bulbs.
I’m pretty certain that they would throw a light up on their own though.
When Doc had my van on his VCDS, he did mention that only certain bulb errors can be coded out on my 2011 can. I think on 2013 and newer vans this is different.
I can’t remember which ones he said couldn’t be coded out though.
Posted: Wed Nov 25, 2020 10:17 am
by RangerD
Ah, bummer. I find that so annoying. I have LED DRLs too, but they are (pretty much!) error free. Sometimes they bring up an error light, but if you turn sidelights or headlights on for a few seconds, then turn them off again, the error light goes away. This is now cancelled out by my plate lights! Someone did try to code the error out for me but it seemed to keep recurring so he couldn't do it! The plate lights I have on are so obright though, that they actually help you see when you are reversing!!
Posted: Wed Nov 25, 2020 10:21 am
by the swan fiend
Yeah the light on the dash does my head in. But I can live with it
Why are the travelin lite ones getting so hot? I take it there’s no resistors in them?
Posted: Wed Nov 25, 2020 10:42 am
by RangerD
I think the resistors are actually what get really hot. If you buy separate resistors, as you can for DRLs, they need to be mounted somewhere that won't melt for this reason.
Posted: Wed Nov 25, 2020 11:55 am
by the swan fiend
Yeah, they do get very hot mate.
Posted: Wed Nov 25, 2020 4:16 pm
by Doc
I've cracked removing cold and warm lamp diagnostics for all but low beam, high beam and fog lights.
The only one VCDS will do is the license plate lights warm diagnostics, which for the BMW lights is fine. I've been running them for over six months without a fault code and just VCDS coding for the LEDs.
Posted: Wed Nov 25, 2020 4:20 pm
by the swan fiend
That’s good news Doc, so you should be able to get my error light out when I next see you then? I’ve also got lights in the door cards that need coding in too.
What is cold and warm diagnostics mate?
I’ve never heard of that before.
Posted: Wed Nov 25, 2020 4:43 pm
by Doc
Cold diagnostics is the lamp check when you turn the ignition on initially, the CECM/BCM tries each lamp.
Warm diagnostics is when the lamp current consumption is monitored while it is lit.
Posted: Wed Nov 25, 2020 5:02 pm
by the swan fiend
I see mate
Posted: Thu Nov 26, 2020 1:21 am
by hef355
If these bulbs fit onto the old pick ups Pete the back plate lights will be brighter than the headlights lol!!
Posted: Thu Nov 26, 2020 8:39 am
by RangerD
Nice one Doc. I'd be calling on your services for this sort of thing if I didn't live so far away! Maybe it is only the warm diagnostic that brings up the fault on my plate lights, it only shows up after a couple of minutes...
Posted: Thu Nov 26, 2020 8:46 am
by the swan fiend
Put them in the front then Hef
Posted: Thu Nov 26, 2020 9:16 am
by Papa Bear
Or drive backwards
Great job swan
Posted: Thu Nov 26, 2020 9:18 am
by hef355
Posted: Thu Nov 26, 2020 9:29 am
by the swan fiend
