Jimbos mk3 caddy
Re: Jimbos mk3 caddy
Just needed enabeling in the parking assist module
CarPlay is now working aswell was some dodgey wiring or the usb socket.
So just waiting on my mk4 centre console to arrive and then I can see if I can make it work
you'll be glad when it's all done.
Yea defiantly, got the correct sharkfin and some sikaflex on its way aswell,
Just fingers crossed I’ve ordered the correct fakra ends,
Can finally start looking at doing a different mod soo n
Right have I started a new trend for people pissed off without having somewhere for your phone to sit?
Mk4 gear surround in a mk3, requires some Modification as all the mounts match up but are at slightly different angles,
I do have the gear gator aswell just haven’t changed that yet.
Anymore info on this? What you had to get altogether?Gsi_Jimbo wrote: ↑Fri Jun 07, 2019 11:01 am Reverse camera is working!!!!! Was a tick box in parking assist/ steering I had to check
Only issue now is I don’t get the sensor overlay, but I believe that’s cause mines an older park module?
So it looks like I’m going to have to upgrade that to the newer one?
Photos of the head unit installed and the cam?
Alright mate tbh I’d been pretty lazy but seeing this notification made me get my arse into gear and get it sorted,
Housing is right on the edge but had to with the camera I got unfortunately,
That’s the only hole I had to drill, through the body work and handle, could of probably been abit smaller but hey ho.
As you can see from the old to new I’ve removed one bolt and cut the hole for the camera itself.
I had to sikaflex a nut to the back of the camera and housing, going to beef it out more today, but even with what littles on there it’s not moving,
The way I’ve done this the camera and housing is the last bolt which also stops the camera being removed without being inside the van.
I’m sure someone with 3d / cad capabilities could 3d print a housing with nut in it for the camera to make it more factory finish though
Carbon fibre surrounds and 4d plates just arrived aswell so will be chucking them on today
Anyone reading this know what rear led number plate lights will fit the caddy plinth aswell ?
Finally after what feels like forever I have my new clocks in
Big cheers to Eddie-nl for his knowledge and for getting these working
- r1lea
Didn’t take long
Only a month or so finally got them in thou, do look mines better
What to do next
What to do next
Hi mate, great project thread. Have you got a golf/scirocco r wheel fitted now? Could you let me know which bits are needed for a mk3 (2013 model) to get airbag and buttons working?
Reason: Quote removed
Nice work! I was wondering if a mk4 center console would fit a mk3, and it seems like it did! thats on my to-do list aswell. Already have one laying around for it.
I love those clocks you fitted, i might have missed it in the thread, but what is it out of?
