My 2007 VW Caddy 1.9 TDI
sylwiu_3gta
Re: My 2007 VW Caddy 1.9 TDI
Post by sylwiu_3gta » Sun Apr 19, 2020 10:00 pm
Hello! No, it's not exactly a straight swap, but it's not very difficult to do this retrofit. First you'll have to trim a little bit the headliner in order to fit the Passat interior light, then you'll need an adapter loom because the pin order is different and you have an extra wire for the button illumination and red ambient lights. The adapter you can buy it or make it yourself. You have to run also a wire from the light switch along the A pilar an connect it to the Passat interior light to that extra wire I said earlier.
sylwiu_3gta
Post by sylwiu_3gta » Sun Apr 19, 2020 10:26 pm
As an update regarding my van I managed to soundproof the bonet. First I applied the sound deadening and after I mounted the bonet insulation, new offcourse.
I didn't drove it to much thanks to this forced "holiday" so I don't know if it's quieter but for sure doesn't sound anymore like an empty bucket when I close the bonetImageImageImageImage
sylwiu_3gta
Post by sylwiu_3gta » Wed Apr 29, 2020 6:48 pm
Finally I managed to install the door warning lights with VW logo, I only had some red plastics, the door handle illumination and also applied some acoustic foam on the inside of the door cards.
About the door handle illumination, I have to find a method to cover the outer part of the LED so I can't see the light directly.ImageImageImageImageImageImageImageImage
maxthecaddy
Post by maxthecaddy » Sun May 03, 2020 1:29 pm
nice build your doing, i like the led vw logo :) 👌
sylwiu_3gta
Post by sylwiu_3gta » Sun May 03, 2020 9:44 pm
@maxthecaddy thanks mate!Image It's still work in progresImage
I bought also some Touran bases with storage compartments. I complete disassembly, fixed some rust issues and gave the a good clean and put them back together. Now I'm waiting for a good opportunity to mount them on the CaddyImageImageImage
Glen G
Post by Glen G » Sun May 10, 2020 9:11 am
Great looking caddy mate I really like the little touches u have done to interior looks fantastic.. 👏 Is the interior light you fitted hard or easy enough job?
sylwiu_3gta
Post by sylwiu_3gta » Tue May 12, 2020 8:39 am
Thanks @Glen G. It's still work in progress . No, fitting the lights wasn't such a hard job, but took me a little bit of time. If I would do them a second time would be much faster.
sylwiu_3gta
Post by sylwiu_3gta » Fri Jun 05, 2020 5:34 am
I bought a Skoda BLS engine cover at a very good price (almost 4 times cheaper that a VW one) and I gave it a little bit of love. I painted the central piece in silver metalic paint, colored the TDI letters , mounted a VW badge ( I wasn't so lucky just to remove the Skoda badge and find the VW one under, like on the new modelsImageImage), insulated the underside and used some plastic restorer for the exterior piece. I'm pretty happy with the result.....
Now I have also less noise coming from the engine.....ImageImageImageImage
jordancmcb
Post by jordancmcb » Fri Jun 05, 2020 11:01 am
That engine cover looks brilliant. Did you separate the silver section before painting or have you just made a really good job of masking it?
sylwiu_3gta
Post by sylwiu_3gta » Fri Jun 05, 2020 11:28 am
Thanks mate👍! The engine cover is made from 2 separated pieces, at least for BLS engines, so painting was really easy :D . I think on the newer models the cover is in one piece.
C Chis
Post by C Chis » Fri Jun 05, 2020 12:26 pm
It’s looking great!
I’ve just fitted my engine cover to my bls engine, noticeable difference to the noise as well
