2009 2.0 SDI
- BillyGilly
Re: Sprucing an SDI
@James01 Cheers mate, more to do but getting there!
BillyGilly
2016 2.0 TDI Bluemotion: viewtopic.php?f=13&t=40889&p=341148#p341148
2009 2.0 SDI: viewtopic.php?t=40416
Re: Sprucing the SDI
hi mate,
did you carpet lined straight over the original headlining ? and what kind of glue did you use?
van is looking great! following for inspiration!
- BillyGilly
Yes mate, took shelf and headlining out the van. Used stretch carpet and spray adhesive, same as the back of the van cheers
BillyGilly
Nice build so far mate. It’s coming along nicely
- BillyGilly
Cheers mate! Not going to be a show van or anything so not going over the top, just tidying her up a bit
BillyGilly
- brooneye
You’ve done a great job, amazing what a little bit of time can achieve
- BillyGilly
Thanks man! Yeah bits left to do but a little TLC goes a long way!
BillyGilly
- Josh764
Re: Sprucing an SDI
Back looks awesome really tidy.. Exactly what I'm hoping to do to mine.
- BillyGilly
Cheers mate. It makes a massive difference!
- BillyGilly
A quick update...here’s the latest photo of the Caddy next is to see what’s making her poorly
BillyGilly
- BillyGilly
SDI Build
BACK FROM THE DEAD
You’ll have to excuse how well soiled she is but she’s back on the road. New tandem pump, oil dropped and re-filled and she’s as good as new. Just replaced headlight bulbs with some brighter ones, massive difference made! Also, fitted new rear plate lights.
BillyGilly
- BillyGilly
Re: SDI Build
Gave the old girl a clean inside today. Need to get the body done now, just a massive pain this time of year!
BillyGilly
- BillyGilly
SDI Build
Update: long story short, the diesel in the engine oil and smoking was not sorted upon return from the garage...so I decided to fly solo with it. Injector seals was the suspects. Armed with 4 packs of injector seals and a wrench I set to work. All the seals where perished! Once all seals were done, I dropped the oil and replaced with fresh along with a new filter. Sounds easy but as I found, it wasn’t easy with a lowered front end and side bars. A trip to Halfords for a pair of 2T car ramps and it made the job effortless! Now to run it, monitor the engine oil and hope that it’s ok! Starts/runs a dream now though.
BillyGilly
Re: SDI Build
Wheels looks great looking to get some like that on my caddy, great finish from the tins LOVE IT
- BillyGilly
Re: SDI Build
Cheers mate! Plenty of wet sanding & polishing it took..
