2013 Caddy 2.0TDI 4motion (Norway)
Jonny6n2
Re: 2013 Caddy 2.0TDI 4motion (Norway)
Post by Jonny6n2 » Sun Dec 08, 2019 11:37 pm
Van looks awesome so far!
Love the wheels following this thread!
fazerfreak
Post by fazerfreak » Sat Dec 14, 2019 11:09 am
Trying out theese ebay leds.. and some more carpenting ImageImageImage.. nice enough for a divingVan ImageImageImageImageImageImageImage
Sent fra min SM-G973F via Tapatalk
Best Regards
Tommy
fazerfreak
Post by fazerfreak » Sat Dec 14, 2019 5:00 pm
well.. the Led bulbs.. the fit nice and put out lots of light on closerange and not som mutch more on Longrange.. also the "LightPicture" is wrong/strang on closerange.. just like 2 big flashlight..
Best Regards
Tommy
fazerfreak
Post by fazerfreak » Mon Dec 23, 2019 2:36 pm
if i buy a steeringwheel like this (mk7) would it be enough to aktivate cruise controll or do i need more ImageImage merry Xmad to all the readers.Image
Best Regards
Tommy
Post by Doc » Mon Dec 23, 2019 2:40 pm
You won't get a mk7 golf steering wheel to work straight off on your caddy, there's a few supporting modifications required.
Does your van already have cruise control or adaptive cruise control at all? That might be a factor in which wheel you can use.
fazerfreak
Post by fazerfreak » Mon Dec 23, 2019 2:41 pm
oki. thanx.. then i'll let it go..
Best Regards
Tommy
Post by Doc » Mon Dec 23, 2019 2:44 pm
Cool, maybe after the crazy season is over and you can actually us it when the roads are moving free.
Have a great Christmas.
sylwiu_3gta
Post by sylwiu_3gta » Mon Dec 23, 2019 5:51 pm
I see you already have a MFSW so you have the highline steering wheel control module , it means it can support cruise control. The easiest way is to mount a CC stalk and code the module.
fazerfreak
Post by fazerfreak » Tue Dec 24, 2019 7:31 am
thanx, I'll get me a stalk'er in a few days from my TouranPartsCar :-)
i've been looking around about this and notices that there is an extra wire needed ?
Best Regards
Tommy
sylwiu_3gta
Post by sylwiu_3gta » Thu Dec 26, 2019 11:58 am
That would be the diagnostics wire and has to be fitted in case it's missing but I don't think it's your case, mostly on the older generation before 2006...
fazerfreak
Post by fazerfreak » Thu Jan 02, 2020 4:00 pm
Not mutch happening, waiting for more parts.. but ImageImageImageImage
Best Regards
Tommy
fazerfreak
Post by fazerfreak » Fri Jan 24, 2020 7:22 am
Got new plastic for the door ImageImage and mounted a 9' android elCheepO.. works ok but i cant get the vw BT to work with it.. when getting a xall/or make a call the playe doewnt mute or put out the sound from the original vw BT HF.. anyone tryed/made it work ImageImageImage
Controlls on steeringwheel works great, but would be nice to use the Car vw BT HF instead of the one in the player.
Best Regards
Tommy
fazerfreak
Post by fazerfreak » Sat Mar 07, 2020 11:07 am
Dobbel floor for divinhbottles and other stuff ImageImageImage
Best Regards
Tommy
fazerfreak
Post by fazerfreak » Mon Mar 30, 2020 1:59 pm
To day my silver "box" got Stage 1 (soft) upgrade with EGR delete 8)
i chickend out on the 180hp :oops:
Best Regards
Tommy
