Yet another Ex-gas van
EX_gas-Cop
Re: Yet another Ex-gas van
Post by EX_gas-Cop »
Got my covers made by some professionals sewers, after I fed up of how long it took me to make just one cover ImageImageImage
1.6 tdi 100bhp
Ex gas caddy maxi
EX_gas-Cop
I struggled a little doing the fog lights months ago so I thought I'd do a little write up of how I got through the fire wall.
There is a rubber panel in the firewall just behind the engine under the insulation that a gasket went perfect in too and then there a plastic panel behind the fuses that with a little modified extrusion for a hole cutter I could reach to put a hole in it, I used some long bar to drive the cables through both holes and used another gasket and some silicone to seal the hole in the plastic behind the fuses.ImageImageImageImageImage
1.6 tdi 100bhp
Ex gas caddy maxi
sylwiu_3gta
Post by sylwiu_3gta »
Did you conected the fog lights to the BCM or you used the method with the relay?
I bought also a fog lights kit but the harness is made for the relay method so I have to modify it. I bought also a 30 bit highline BCM from a Passat because I want also to activate cornering function, and my BCM didn't even suported the front fog lights. I only need time to do the job, like you said, it's a lot of work and takes time.
Good luck with the project!
Current built thread: 2013 SWB Caddy 2.0TDI
viewtopic.php?f=13&t=48634
My previous built: 2007 SWB Caddy 1.9TDI
viewtopic.php?f=13&t=39945
EX_gas-Cop
It came with an extra relay, it was just the travelin-lite kit they do and I did it as per instructions Haha I didnt know about connecting them to the BCM
1.6 tdi 100bhp
Ex gas caddy maxi
This is a nice looking build mate. The work you’ve done in the back looks super neat
One question though....what work did you do that required a sledgehammer???
EX_gas-Cop
@the swan fiend thank you mate, oh the sledgehammer Image I was using it only as a weight because I bonded those wood strips so along the edge so I had thinker material to screw the bed frame down to keep it secure, instead of just going through the laminate so only the side I know I've got just under 20mm at least to screw in too ImageImage
1.6 tdi 100bhp
Ex gas caddy maxi
That’s a good use of a sledge mate! Beats using it for dent removal
EX_gas-Cop
Remembered to take some photos of how I butchered the dash for the touran glove box while fitting my speakers today lolImageImage
1.6 tdi 100bhp
Ex gas caddy maxi
EX_gas-Cop
The passenger side is all wired in with my new vibe black air component speakers I trailed the tweeter cable through the loom bit. Need to make some adaptors out of some ply for the tweeters now and sort the touran door card out needs trimming round the mirror bit.ImageImageImageImage
1.6 tdi 100bhp
Ex gas caddy maxi
Lad.In.A.Cad
Post by Lad.In.A.Cad »
Those door shut wiring loom boots are such a pain to unplug the first time!
Looking clean
EX_gas-Cop
That one wasnt to bad for me luckily
Thanks man
1.6 tdi 100bhp
Ex gas caddy maxi
EX_gas-Cop
Here's my little mount I made for the tweeter, out of some 2mm ply i made a stencil then just cut it out and painted it with Matt black paint Image
Sent from my SM-G970F using Tapatalk
1.6 tdi 100bhp
Ex gas caddy maxi
EX_gas-Cop
Just a quick update for some of the stuff been doing over past couple weeks, progress has really slow down on the van because of work, but re covered my arm rest ready to fit my touran centre console and changed the gear knob, and got some.heated half electric passat seatsImageImageImageImageImage
1.6 tdi 100bhp
Ex gas caddy maxi
JusrajC
Post by JusrajC »
How have you installed the camera to the rcd330 I have the same setup and I think the camera is the same looks oem but it doesn’t connect to the head unit for some reason I was told I need an adapter to make it av but it is and about camera so I’m stuck.
EX_gas-Cop
@JusrajC did you manage to find someone with VCDS local to you, as I said on instagram you may still need to turn it on, I've bought a 12v camera filter just off ebay but I'm still having problems as mine has stopped working, or do you mean about like the cables and that?
1.6 tdi 100bhp
Ex gas caddy maxi
