Page 2 of 7
Re: Yet another Ex-gas van
Posted: Wed Nov 20, 2019 5:12 pm
by EX_gas-Cop
Got my covers made by some professionals sewers, after I fed up of how long it took me to make just one cover
Posted: Wed Nov 27, 2019 9:32 pm
by EX_gas-Cop
Posted: Thu Nov 28, 2019 8:40 am
by sylwiu_3gta
Did you conected the fog lights to the BCM or you used the method with the relay?
I bought also a fog lights kit but the harness is made for the relay method so I have to modify it. I bought also a 30 bit highline BCM from a Passat because I want also to activate cornering function, and my BCM didn't even suported the front fog lights. I only need time to do the job, like you said, it's a lot of work and takes time.
Good luck with the project!
Posted: Thu Nov 28, 2019 9:03 am
by EX_gas-Cop
It came with an extra relay, it was just the travelin-lite kit they do and I did it as per instructions Haha I didnt know about connecting them to the BCM
Posted: Thu Nov 28, 2019 9:06 am
by the swan fiend
Posted: Thu Nov 28, 2019 9:12 am
by EX_gas-Cop
@the swan fiend thank you mate, oh the sledgehammer
I was using it only as a weight because I bonded those wood strips so along the edge so I had thinker material to screw the bed frame down to keep it secure, instead of just going through the laminate so only the side I know I've got just under 20mm at least to screw in too
Posted: Thu Nov 28, 2019 9:18 am
by the swan fiend
That’s a good use of a sledge mate! Beats using it for dent removal
Posted: Thu Nov 28, 2019 10:11 pm
by EX_gas-Cop
Remembered to take some photos of how I butchered the dash for the touran glove box while fitting my speakers today lol
Posted: Thu Nov 28, 2019 10:15 pm
by EX_gas-Cop
Posted: Thu Nov 28, 2019 10:28 pm
by Lad.In.A.Cad
Those door shut wiring loom boots are such a pain to unplug the first time!
Looking clean
Posted: Thu Nov 28, 2019 10:30 pm
by EX_gas-Cop
That one wasnt to bad for me luckily
Thanks man
Posted: Sun Dec 08, 2019 9:11 am
by EX_gas-Cop
Here's my little mount I made for the tweeter, out of some 2mm ply i made a stencil then just cut it out and painted it with Matt black paint
Sent from my SM-G970F using Tapatalk
Posted: Thu Feb 06, 2020 2:25 pm
by EX_gas-Cop
Posted: Sun Feb 23, 2020 12:43 pm
by JusrajC
How have you installed the camera to the rcd330 I have the same setup and I think the camera is the same looks oem but it doesn’t connect to the head unit for some reason I was told I need an adapter to make it av but it is and about camera so I’m stuck.
Posted: Mon Feb 24, 2020 8:08 am
by EX_gas-Cop
@JusrajC did you manage to find someone with VCDS local to you, as I said on instagram you may still need to turn it on, I've bought a 12v camera filter just off ebay but I'm still having problems as mine has stopped working, or do you mean about like the cables and that?
