Today I finally got round to fitting the speakers I bought about 6months ago!
Used rivnuts and m5 bolts to fit the speaker adaptors following what others have done on here.
Would recommend that.. Really solid even on the plastic adaptors.
Modest amount of deadening on the outer skin and inner door panel.
Butchered the original tweeters and inserted the new ones in thier place. Then fed the tweeter cables down to near to where the original loom cables go through to the door.
Identified and spliced into the original speaker wiring here to give input and door speaker output and mounted the crossover to the chassis.
Also put some left over insulation on the backs of the door cards whilst I was there.
VERY happy with the results.. Deadening has reduced the road noise and the speakers sound much better with the underseat sub where it stood out a bit much when I had the original speakers in.
Sent from my SNE-LX1 using Tapatalk
