My project caddy2k (work van)
CaddyAnt
Post by CaddyAnt » Mon Jan 27, 2020 8:29 pm
Hey guys so thought I’d post up a build thread as this will
Be a good one..! So far I’ve fitted stance + coil over kit with rear axle flipped, mk6 golf gtd 19’wheels, black Vw badges, Vw engine cover, touran under bonnet Insulation, new style rear lights,kenwood Apple play double din head unit, kenwood dash cam, golf mk6 gti flat bottom multi function steering wheel, touran black carpets, touran Center console with arm rest.
This summer I will be doing an engine conversion to get around the ulez charge which will be r32 3.2 v6
Lister79
Re: My project caddy2k (work van)
Post by Lister79 » Mon Jan 27, 2020 8:44 pm
Welcome to the forum. Looks good, will be watching your thread to see it progress.
2014 Toffee Brown 1.6TDi
CaddyAnt
Post by CaddyAnt » Mon Jan 27, 2020 8:49 pm
Thank you very much.! Yes it will be one to watch
Giddy
Post by Giddy » Mon Jan 27, 2020 9:18 pm
Welcome to the forum. Sounds like you know what you do, will be interesting to follow the progress.
Caddy 4, Highline, 1.4 TSI
Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
CaddyAnt
Post by CaddyAnt » Mon Jan 27, 2020 9:22 pm
Giddy wrote:Welcome to the forum. Sounds like you know what you do, will be interesting to follow the progress.
Thank you, yeh I’ve always wanted an r32 golf so why not just fit the r32 engine in the caddy... best of both worlds work van while having the nice power when needed
CaddyAnt
Post by CaddyAnt » Sat Feb 01, 2020 4:40 pm
So ended up buying a set of Vw scirocco r steering wheel button trims and fitting them like a lot more hidden to the chrome still need to be coded in but that Ben done soon ImageImageImage
