Pure Grey Caddy Maxi Life
GreyLife
Re: Pure Grey Caddy Maxi Life
Post by GreyLife » Wed Mar 04, 2020 8:51 am
Hi Chris, here is the trim under the driver's seat. Sorry I can't see any part numbers, they are probably on the underside of the trim?Image
Sent from my Nokia 1 using Tapatalk
chrisd317
Post by chrisd317 » Wed Mar 04, 2020 11:23 pm
its the trim at the front of the rear seats if that makes sense? if you open the sliding door and look at the front of the rear seat where the carpet comes up from the footwell
thanks for the help
Chris
GreyLife
Post by GreyLife » Sat Mar 07, 2020 4:24 pm
Hi Chris, have a look at this photo. I took out the single seat while cleaning today. Still can't see any part numbers as I guess they are at the back of the trim pieces. Hope this helps you a bit!Image
GreyLife
Post by GreyLife » Sat Mar 07, 2020 4:27 pm
So after a clean today I decided to finish de-badging the tailgate. I took the 'TDI' off several months ago to see how easy it was to remove. I think it looks a lot crisper without the 'BlueMotion' and 'Caddy' badges!ImageImage
chrisd317
Post by chrisd317 » Sun Mar 08, 2020 2:08 am
Hi Chris, have a look at this photo. I took out the single seat while cleaning today. Still can't see any part numbers as I guess they are at the back of the trim pieces. Hope this helps you a bit! Image
Hi mate, the phot hasn't uploaded
GreyLife
Post by GreyLife » Sun Mar 08, 2020 7:53 am
Here it is again Chris.Image
GreyLife
Post by GreyLife » Tue May 05, 2020 5:27 pm
Small job done on the Caddy today. Since we have previously used the van as a basic camper, I have wanted to add a boot release so that the tailgate can be opened from the inside - makes it easier to get out.
So, I removed the back panel to see how the boot lock works, and found that all that is required is a little lift up of the catch. Measured out and drilled a hole and used a cable grommet to finish off. The boot can now be opened from the inside!ImageImageImage
