Page 1 of 4
Maxi workhorse
Posted: Fri Feb 28, 2020 10:06 am
by R22LRM
Re: Maxi workhorse
Posted: Fri Feb 28, 2020 10:10 am
by R22LRM
Re: Maxi workhorse
Posted: Sat Feb 29, 2020 1:37 pm
by Ripley55
2 Caddy’s
Now that sounds awesome
I’d love to, but I’m 100% certain, I’d be divorced by the end of the month
Re: Maxi workhorse
Posted: Sat Feb 29, 2020 2:05 pm
by R22LRM
Ripley55 wrote:2 Caddy’s
The other half isn’t impressed
Re: Maxi workhorse
Posted: Thu Mar 05, 2020 2:42 pm
by R22LRM
Few little jobs boxed off today:
Van x led winkle pickers:
Caddy alltrack smoked rear lights:
Gti mk5 steering wheel:
Re: Maxi workhorse
Posted: Thu Mar 05, 2020 4:20 pm
by R22LRM
Next jobs gti breaks & stance coil overs:
Re: Maxi workhorse
Posted: Thu Mar 05, 2020 4:28 pm
by Doc
You are missing the carriers from the rear brakes in that photo, that's essentially the only part you need as the calipers are a different piston size and not suitable for use on a Caddy.
Re: Maxi workhorse
Posted: Thu Mar 05, 2020 7:46 pm
by R22LRM
Doc wrote:You are missing the carriers from the rear brakes in that photo, that's essentially the only part you need as the calipers are a different piston size and not suitable for use on a Caddy.
Ahh ok thanks for heads up doc, so the caddy callipers will work with the 286mm discs if I get the carriers?
Re: Maxi workhorse
Posted: Thu Mar 05, 2020 7:50 pm
by R22LRM
Think I have some callipers and carriers off my white one that had 282mm rear discs on it when I upgraded to r32 rears will they fit the maxi?
Re: Maxi workhorse
Posted: Thu Mar 05, 2020 11:36 pm
by Doc
Without knowing exactly what you have to fit and what is fitted I can't advise 100%, that said I and many others have fitted rear caliper carriers from a GTI and put the caddy caliper onto that without an issue.
Re: Maxi workhorse
Posted: Fri Mar 06, 2020 7:43 am
by R22LRM
Doc thanks again saved me a bit of head scratching there
Re: Maxi workhorse
Posted: Wed Mar 11, 2020 12:51 pm
by R22LRM
Freshly painted rims, wrapped in lovely falken rubber ready coils now
Re: Maxi workhorse
Posted: Thu Mar 19, 2020 10:50 am
by R22LRM
Easiest modification ever heko wind deflectors:
Re: Maxi workhorse
Posted: Thu Mar 19, 2020 10:55 am
by R22LRM
Freshly painted front gti callipers and discs:
Re: Maxi workhorse
Posted: Thu Mar 19, 2020 12:46 pm
by R22LRM
Roof bars installed:
