OCD Caddy Demo
OCD Caddy Demo
Hi all!
Recently picked up an 05 Caddy C20 1.9TDI, 156k on the clock.
Doesn't appear to of been a works van through its years so it in pretty good condition. The odd dent & scuff, but best point being there's no serious rust at all, just the bottom corner of the drivers door is starting to bubble.
It has had an odd bump on the passenger front but plans are to swap out the front for 07 Touran setup
I've bought this as we're planning to reinvigorate our old rear air suspension conversion. We previously worked with SRS Auto to create a rear suspension setup that allowed for both air & coil, it was a great setup, but over engineered really. Making it tricky to install, lots of parts to be produced and pretty costly.
So we're going version2, back to the drawing board from all we've learnt doing that setup, from other projects we've brought ideas from and also seeing what else is available for the Caddy's in way of air suspension.
No plans on advertising here at all, but rather just a document of the general mods we carry out and the design & testing of our new rear air kit.
The van is going to be my daily, so it's not going to be a complete one off build, however I do hope it turns out looking smart with plans I have
So here's the van as we got it -
The test bed for our old rear 4 Link setup that will be the test bed for V2 as well -
Then I found a guy breaking his 07 Touran just a few days after I'd picked up the Caddy. He had everything I wanted and more already stripped from his Touran, made a deal and he kindly packed and wrapped all the parts ready for me to have collected. They arrived at our shop yesterday morning -
Thanks guys and I hope to be back soon with some updates of the Touran parts going on.
- Matt
- Matt
- Giddy
Re: OCD Caddy Demo
Hi Matt, sounds like an interesting project! Cant see the pictures though, perhaps some privacy settings on your google drive?
Re: OCD Caddy Demo
Thanks man.
Yeah, wrote this on my phone this morning. Going to check them on computer Monday and see if I can get it working properly
Re: OCD Caddy Demo
Sorted the photo's out
Also started a blog about the build on our website too - https://www.onlychargeddubs.co.uk/blog/ ... -van-crew/
Starting on the front end conversion today & over the weekend. Will be back with progress photos...
- Lamby00
Re: OCD Caddy Demo
Are you putting the V2 front end on this? I wish I had the time and skills for that look forward to seeing this!
- brooneye
Re: OCD Caddy Demo
I’ll be following this one, keep the updates coming
Re: OCD Caddy Demo
Lamby, yeah 07 Touran front, I'm guessing that's V2?
Got most of it on today, just touching some rust up on the wings before they go on.
Also found I'd not got the panel to swap how the slam panel mounts to the top of the arches. So I might be either put on hold finishing it, or modding the Caddy part to mount up.
Likely the later as my patience isn't so good haha
Should get some more photos up on Sunday for you guys.
- Lister79
Re: OCD Caddy Demo
Interesting stuff mate, will definitely be following to see how the van and rear setup develops.
Re: OCD Caddy Demo
Cheers guys.
So I made a start on the front end conversion yesterday and pretty much finished it up this afternoon.
Also the first time I'd managed to get the Caddy on a ramp, so had a quick nosey round and found a tasty looking rear silencer swap
That won't be staying for long haha
Also found drivers spring snapped, but handily found a little place to live!
On to the front end swap over, set the Caddy up & laid out the main parts of the swap.
The swap started well, the original front flew off, no nasty surprises anywhere. Found a couple of flaky spots behind the wings so rubbed those back and stuck some underseal on them to help prevent any more growth. Base of the sills where mud commonly gets stuck also solid, but cleaned these out and again slapped some underseal in there too.
Next up, we sized the slam panel on the front. The radiator & intercooler mounted straight up, I was hoping this would be the case but wasn't sure it would be.
However the issue we found is the panel at the end of the chassis where the wing mounts is different. It raises up and has the slam panel bolts on an angle. Where as the V1 front they're horizontal to each other.
I spoke with the guy I got all the parts from, unfortunately he'd already chopped his Touran in half (using the back for a trailer) and sent the front to the scrappies!!!
So I set about with a selection of cutting & grinding tools, making space for the slam panel to sit without any tension. 3 rivnuts set each side and the wings mounted up fully. I'll be 3D printing a set of spacers to make up the height difference in the OG chassis ends & the new slam panel. These will just support it properly with some new bolts in place
Lots of on & off with the slam panel, slight cuts & changes to the chassis ends to get it sitting well. Then the same testing the headlights, until they mounted with out obstruction.
I then flat back cut edges to smooth them, cleaned them up and painted in Por15 to stop any rust starting. Also cleaned up the edges of the wings, bottom corners & arch taking any flaky paint off, then painting in Por15 to stop the rust.
I've going to get an HID kit and new bulbs, so it's not 100% yet, but I test up the bumper so I could set all the gaps & made sure the bonnet closes correctly and looks right. Happy to say all is good, so overall it went really well. Looking forward to bolting it all up for good and moving on to the interior next week
Only thing I'm unsure on is the wing mirrors & indicators, with them moving from the wings to the mirrors, do I have to move the wiring? Or just change the coding?
I'm guessing it's covered on here somewhere, but if someone knows the thread to search or has the link that would be greatly appreciated
Best, Matt
Best, Matt
Re: OCD Caddy Demo
Had a couple more hours today to finish off a few loose ends before we're back to normal work tomorrow
Rolled the front arches, getting ready for the suspension & wheel changing when that comes around.
CAD'd some spacers for the lock carrier & set those printing on our 3D printer. So while I waited for those, I stripped down the front door cards, window regulators & cleaned everything up.
Spacers took a couple of hours, but came out well
The space left in height difference between V1 & V2 slam panels
Spacers installed & all tightened up
Next job on the list is to apply some sound deadening inside the door skins. Window regs back on, new speakers in & Touran door cards and wing mirrors on. Then I'll start on the dash swap & carpets
Thanks...
Thanks...
- Lister79
Re: OCD Caddy Demo
Sounds good but none that f the photos are working for me.
- Lamby00
Re: OCD Caddy Demo
The same goes for me. I can see the photos from my PC - via google chrome. But I cannot see them on Tapatalk on my mobile.
Re: OCD Caddy Demo
It must be something with tapatalk? I've used imgbb to upload then paste the links over too. I'm only ever on Chrome or google through my phone, I don't use tapatalk as I always found it really annoying haha
Sorry guys!
Sorry guys!
- Giddy
Re: OCD Caddy Demo
Works ok for me on laptop or tapatalk (android phone).
Re: OCD Caddy Demo
Great progress, look forward to seeing what you get up to with this.
Picture work fine for me on Chrome (Windows) and Tapatalk (Android).
