- J_Con
Re: Let the build begin
Might give it a go if I'm brave enough! Got a touran console there ready to fit! Loving the work mate vans looking ace! Hope Ed was able to sort you out with your cluster
Sent from my LYA-L09 using Tapatalk
- C Chis
Cheers and thanks for the referral
3D cluster and spare remotes should be here sometime through the week
- Papa Bear
Look forward to seeing that fitted
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- J_Con
Will definitely make a big difference! Can't recommend him enough
- Papa Bear
Is that the cluster you showed on page 19?
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Lister79
Looking good mate, well done.
- C Chis
Let the build begin
[mention]Lister79 [/mention] cheers buddy!
[mention]Papa Bear [/mention] erm... no that was a highline, red display from a Touran, I’ve had a change of mind/direction... pictures to follow once installed
- Papa Bear
Lol thought so.
Waiting to hear what’s needed and how much before adding to my list
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- J_Con
You won't be disappointed if im assuming correct! Made such a difference to my van
- Papa Bear
My display is white, no idea what it is known as but as I have an aftermarket stereo, not sure it would be that much better upgrading other than looks.
(Says the guy spending ages putting blue LEDs everywhere)
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- C Chis
Yeah, saw some images of the 3D clusters and for the price difference and the benefit of only having to have the cluster coded once, I thought, might as well! Although it will detract from the red theme I had going...
Hopefully I’ll be able to lower my van early next week while waiting on the cluster being coded.
- Papa Bear
You went red, I’m going blue, anyone going white?
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- ACalamita
Damn nice build dude!
Just read through (most of it) start to finish
A lot of stuff is on my list too... Have a few VAG breakers nearby which I'm off to raid again!!
Deffo following more updates on this.
- C Chis
Cheers buddy!
I’m amazed that you’ve taken the time to scroll through my build, much appreciated!
Make your list before heading to the breakers, it’ll help with your spending, trust me on this one, it’ll stop you getting sidetracked and coming home with loads of other stuff
Van’s now off the road for a few days waiting on a couple of improvements
- Papa Bear
I thought it was law to go to scrappy and come back with more than you intended
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
