Caddy Maxi 2.0 tdi cr 4motion 2012 modifying
TommyTurbo
Post by TommyTurbo » Wed Mar 25, 2020 12:15 pm
:D
Hi valued members :D
I have start building stereo in my newly bought VW Caddy Maxi 2.0 TDI CR 4MOTION 2012.
First step was to replace the original car audio player. Have the Android player and speakers from my VW Transporter T5 2.5 TDi 4motion I have sold.
JOYING Android from 2019.
B2 Audio HNT1 tweeter in top of the dashboard , but they where to long /high, so I had to cut a bit in dashboard. I'm not really satisfied with the result and I will try to cut a bit more later...
B2 HN8P 8" mid range speakers in doors, but after several hours of trying to modify and cutting in door panel backside, I decided to skip those speakers for this time... They are too big and have to build a new panel section in door for good fitment... :shock:
I will try to find some 6.5" good quality speakers for the doors.
Later I may be installing 12" subwoofer from DD and build a new speaker box in the rear inside of the car.
Unfortunately I don't understand how to upload pictures, but I think it is because I'm new i in this forum and have to make a lot of threads before I can look and post more....
R22LRM
Re: Caddy Maxi 2.0 tdi cr 4motion 2012 modifying
Post by R22LRM » Fri Mar 27, 2020 6:58 pm
Hey, sounds interesting I would like to the pics, if you use Tapatalk it’s so easy to upload pics
R22LRM
Mk5 Tfsi powered
TommyTurbo
Post by TommyTurbo » Fri Mar 27, 2020 8:53 pm
Unfortunately I'm not allowed in this forum to do a lot of things... Before I have at least, 5 threads
Post by Doc » Sat Mar 28, 2020 4:31 am
Welcome to the forum.
There's nothing stopping you attaching photos to a post, there are no new member restrictions on that.
