Caddy K1 conversion
Brian383
Re: Caddy K1 conversion
Post by Brian383 » Wed May 13, 2020 11:04 pm
Fran9r wrote: โ†‘
Wed May 13, 2020 10:04 pm
Great looking vans. I presume using the donor wiring loom makes life easier? I have a Scirocco donor to do the same with.
Yes bud both vans have the complete donar car looms in them with zero problems
Brian383
Post by Brian383 » Wed May 13, 2020 11:13 pm
Got a delivery today from tps with the front an rear lips for the white caddy well pleased with the fit as I didn't want it scraping the ground painted them tonight an fingers crossed fit them in the morning think I'll do the middle bits satin black as the silver will look silly๐Ÿ™ˆ
Brian383
Post by Brian383 » Sat May 16, 2020 6:45 pm
Got the lips on an a we clean today
Fran9r
Post by Fran9r » Fri May 22, 2020 8:23 pm
Brian383 wrote: โ†‘
Thank you for that.
Did you get any issues with the with the block connectors? I heard a story about them not fitting through the bulkhead.
How did you work out what resisters to use in the missing airbag wiring?
I'm going to put a Scirocco front end on a Maxi (2.0 TSI) so any pointers would be awesome. I think the subframe should bolt up, then just use the Caddy lights on a Scirocco loom.
Brian383
Post by Brian383 » Sun May 24, 2020 9:44 pm
Fran9r wrote: โ†‘
Thank you for that.
Yea on the pass side I cut the hole slightly bigger the made a small plate with a seal an used rivit nuts an new bolts so now I can Un bolt a small corner if I ever need it out again. Every thing fitted through the drivers side.
As for the resistors I always use a resistor 2.7omh in anything I doing it with an it worked 100%.
Subframe should bolt stright in use the steering rack an abs pump as the all coded together
You'll find the light will plug stright in the only wires I had to make a bit longer was the ds headlight plug an the plug for the headlight switch in side think that was because it was all out of the K1. The 2nd van (grey one), was all from a Mk5 gti an plugged stright in.
I've now bought a 2012 fr leon for a caddy build for myself an a 2010 audi tt for another caddy for a friend.
When I do these I wana do an awd rs3 powered Mk4 van an sell my own ones
Fran9r
Post by Fran9r » Tue Jun 02, 2020 3:06 pm
Awesome thank you for the details, much appreciated.
Brian383
Post by Brian383 » Fri Jul 10, 2020 11:11 pm
Got the photo bucket working at last
Got the lips on it
Anton
Post by Anton » Sun Jul 12, 2020 2:13 am
Looks tidy pal, nice work!!๐Ÿ‘๐Ÿ˜Ž
Brian383
Post by Brian383 » Wed Jul 15, 2020 1:15 am
Cheers anton
Got some k sport 8 pot calipers an 356mm discs today
Colour change coming up
sadler85
Post by sadler85 » Thu Jul 30, 2020 7:48 am
Morning,
Firstly great build, looks the part.
Ive got a donor A3 2.0TFS (2006) I am I right in saying this too is the same as the MK5 GTI and so therefore again should bolt in if im to use the steering rack, abs pump and subframe?
Falix
Post by Falix » Sun Aug 02, 2020 8:28 pm
Love the build!
How hard was the wiring? Any tips?
Brian383
Post by Brian383 » Mon Aug 24, 2020 12:54 am
sadler85 wrote: โ†‘
Morning,
I haven used an a3 yet but I'm sure it will be simular I've use a Mk5 gti dsg an 2x leonsan they were all very much the same
Brian383
Post by Brian383 » Mon Aug 24, 2020 12:55 am
Falix wrote: โ†‘
Love the build!
Cheers bud
I use the full loom from the donar car all guite simple tbh most of it is bolt stright in
danlewis23
Post by danlewis23 » Thu Aug 27, 2020 1:58 am
i have a 2007 vw caddy and a 2006 audi a3 2.0tfsi i want to put the 2.0tfsi into the caddy could you shed some light on the wiring side if possible? thanks
Pritchard182
Post by Pritchard182 » Fri Aug 28, 2020 1:31 pm
Great build. Very nice looking van two
