Mouse's MTB Day Van/Camper
Mouse
Post by Mouse » Wed May 06, 2020 11:01 pm
Hey, so had my Caddy almost a year with the intention of converting into a Day Van/Camper to use primarily for Mountain Bike trips, making slow progress so thought I'd share where I am at with my build and any future developments.
First picture for attention.
Okay so here we go, Started out by removing the ply shelving, liner kit, floor and bulkhead and gave it a good clean up.
followed up with some sound deadening and insulation.
I used self adhesive roof flashing as a cheap alternative to deaden the panels and arches, packed all the hollow areas with recycled plastic insulation wool and covered all the bare metal (floor/walls/roof) with ThermaALL bubble foil.
tbc....
Mouse
Re: Mouse's MTB Day Van/Camper
Post by Mouse » Fri May 08, 2020 11:25 pm
Part 2;
Built the framework for my bed/storage box and had some panels and metal edging cut to size. the top is hinged and folds out when needed in bed mode. I had an Ikea coffee table that was to be scrapped and turns out the legs were ideal for what I needed, they simply screw in when needed. for storage I currently use 2 Euro boxes that slide in/under the box. I have plans on adding pull out drawers on both ends of the box to replace this.
Next up I recently carpeted the ply lining, barn door frame and the cut down bulkhead.
I also used the opportunity while the panels were removed to add some more recycled plastic insulation, a friend of mine suggested using the spray adhesive for this and it worked a treat! (Previously had parcel tape holding it up)
more to come later.
Mouse
Post by Mouse » Sun May 10, 2020 10:30 pm
Took inspiration from Dunch88's post for an internal door handle for the barn doors https://www.caddy2k.com/forum/viewtopic ... 82#p355482
I used the handle from a spare door card I have from upgrading to electric windows and removed the door release cable/mech from a Touran. used an L shaped bracket and bolted to unused threaded hole. Then tapped new threads into an existing hole that when pulled upwards opens the door.
I then had a friend weld the end of the cable release onto the end of the bolt.
all fitted and working, I do however need to get a replacement door release handle as I snapped the surround.
Mouse
Post by Mouse » Fri May 22, 2020 10:02 pm
So I've just bought a set of 17" alloys for my caddy. But before I fit them I want to sort the ride height. Don't want to go crazy low, just enough so it doesn't look like a tractor, also will I need a centralising plate?
Currently looking at these, anyone used them? Are they a good purchase or do you recommend another kit? Don't want 5o pay more than £300.
https://www.ebay.co.uk/itm/262731281079
Cheers, Mouse Image
Sent from my EML-L29 using Tapatalk
M99ABE
Post by M99ABE » Sun May 24, 2020 2:54 pm
Looking good, I’m just about to lower mine, went for a stance kit. Again not wanting to drop it to low just enough to stop it looking like it’s been jacked up I was wondering about the plates also
