Mouse's MTB Day Van/Camper
Papa Bear
Re: Mouse's MTB Day Van/Camper
Post by Papa Bear » Wed Jul 15, 2020 5:17 pm
Looking great, is that a drive awning or a tent?
We are looking out for one.
Did you solve the split charge relay issue?
Black
Marmite lover!!!
VCDS
Mouse
Post by Mouse » Wed Jul 15, 2020 10:24 pm
Thanks @Papa Bear , nah not had chance to look into the relay tbh.
It's a tent made by Quechua that I bought from decathlon a few year ago for £60. Unfortunately the have been discontinued.
It's ideal, the side that the caddy is backed up onto fully unzipps and can be used as an awning (or just pulled up over the roof of the caddy, and you can have the barn doors opened up (will work with a tailgate as I've used it with a touran) on the opposite side is a smaller door I use for access and the side has a window that opens up.
They do sell an inflatable one that's quite similar but it's priced at £200.
https://www.decathlon.co.uk/la-air-base ... 61168.html
Sent from my EML-L29 using Tapatalk
Mouse
Post by Mouse » Wed Jul 15, 2020 10:34 pm
Today after work I set about installing some wood cladding to the ceiling and also installed the remaining 3 spot lights that light the caddy up really well!
The cladding was a slow process at first as I had to make the 2 end pieces fit around the bulk head ends. Then it was plain sailing from there on in, untill I got to what would have been the final piece in the centre where I ran out of panels, also the gap at one end is wayyy bigger than the other. Not sure if that's due to the shape of the van itself or my shoddy carpentry skills
Also fitted my bed/storage box, cooler and a 3 drawer unit I rescued from going to landfill, which now houses my cooking/eating utensils. ImageImageImageImageImageImage
Mouse
Post by Mouse » Sat Jul 25, 2020 2:10 pm
Finally got around to swapping out my door cards to some from a touran.
They look so much better than the standard light grey plastic cards that were originally in.
Just needed a quick alteration to make them fit (thanks to @C Chis on the info)
Swapped out the handles as I wasn't keen on the chrome plus didn't need the electric mirror switch, also had to swap the window switches as they ones fitted didn't work fully.
Electric window and door cards upgrade finally completed ImageImageImage
C Chis
Post by C Chis » Sat Jul 25, 2020 3:16 pm
Your van’s taking shape!
You managed to get out and use it for some biking yet?
My MTB Caddy Build Can be Found Here
Mouse
Post by Mouse » Mon Jul 27, 2020 10:23 am
Cheers bud, Really happy with the progress so far.
Still not been biking since getting injured, still a few weeks left till I'm healed enough to ride MTB, heading up to Scotland this weekend though, now that the Caddy is at a usable stage as a camper :)
Mouse
Post by Mouse » Mon Aug 03, 2020 8:40 am
Headed up to Scotland over the weekend to give the caddy its first proper outing.
Figured out some changes/improvements I need, to make things a bit easier.
*may need to raise the suspension up a touch as it bottoms out a bit.
*easier access to storage boxes, as I can only (with a struggle) access one box while inside the van (and only if the bed isn't set up)
* Food/cooking: fridge, gas stove, and utensils are all in different areas. Which is a faff! I want to add a pull out storage unit that house all of these, meaning I can have a quick and easy setup and get the coffee brewed and food on the go ASAP.
* Loki (my dog) loves the outdoors and if it's muddy or full of water he's in it, I need to source some durable and well fitting deat covers (for tourans seats)
Also thinking of some kind of build that can go in place of the front seat so he has his own area to sit while on the road and to sleep at night.
*electrics: need some extra plug in points on the opposite side of the caddy.
Going to make some of these changes to my current set up, but toying with a complete overhaul for a (hopefully) more comfortable camping experience.
Also the midges are vicious bastards! ImageImageImageImageImageImageImageImageImage
Mouse
Post by Mouse » Fri Nov 27, 2020 7:42 pm
Winter boots on :DImage
reflectionghost
Post by reflectionghost » Sun Nov 29, 2020 3:43 pm
Nice. Are the steels 17s?
ngc
Post by ngc » Fri Dec 04, 2020 3:32 pm
Very nice pics, mate
Caddy 1.4 TSI - 131 HP
Mouse
Post by Mouse » Thu Dec 10, 2020 3:01 pm
reflectionghost wrote:Nice. Are the steels 17s?
Cheers pal, they are 16s I believe they were from a Seat Leon, picked em up cheap from FB Market place (1 was brand new) . Cleaned them up the best I could then few coats of grey primer, main colour and lacquer before getting new tyres fitted
