Tagllana1
Post by Tagllana1 » Mon Sep 07, 2020 7:44 pm
Hey FishermansFriend,
That;'s a lovely looking wheel! Just a quick question RE those pedals (not sure if it's mentioned previously in the thread). Did you fit them? If so, do you have any links etc?
Post by FishermansFriend » Mon Sep 07, 2020 8:15 pm
Hi Tafllana1,
Yes I fitted them myself and if I can do it you can to, trust me. Its pretty straight forward. There is a detailed tread in the "How To" section of the forum which is very helpful, not sure if you have the access yet but? I bought the pedel set on ebay from a seller called vw-audi-teile-spezi. The listing is "VW Golf 5 6 original GTI pedal pads caps RHD right hand drive covers R32 pedals". Let me know if you need anymore info.
Tagllana1
Post by Tagllana1 » Mon Sep 07, 2020 8:36 pm
Ideal - Found them!! :) Thanks for that,
Was the accelerator easy to swap out? Looks straight forward, bolt out and then bolt the new one in?
Post by FishermansFriend » Mon Sep 07, 2020 10:16 pm
Good, glad you found them. After you take out the bolt there are two retaining clips that need released, push the carpet down so you can get a good view of the clips and you will be able to see what way the clips need to be pushed, use a small screw driver for this, the two clips are at the foot of the base. Once the clips are released the base will come off.
The GTI base wont fit on to the Caddy as the retaining clips dont match, you will need to take the actual accelerator pedal off the GTI base and put it on the Caddy base, then reinstall the Caddy base with the new GTI accelerator pedal. Use a screw driver to gently force the clip on the Caddy accelerator pedal over the clip on the Caddy base, once this is done the accelerator pedal will slide off. Repeat the process with the GTI pedal and base and install the GTI pedel on the Caddy base.
Tagllana1
Post by Tagllana1 » Tue Sep 08, 2020 7:03 am
Spot on :) really helpful, thank you very much. I shall get them ordered and give it a go!
Stev3
Post by Stev3 » Tue Sep 08, 2020 3:34 pm
looking good
Post by FishermansFriend » Thu Sep 24, 2020 10:52 am
Some pictures of the van on the Eibach Pro-Kit.
Tagllana1
Post by Tagllana1 » Thu Sep 24, 2020 10:55 am
That looks the business!!! Are those wheels 18s or 19s?
Post by FishermansFriend » Thu Sep 24, 2020 6:54 pm
Hi Tagllana, they are 19".
Dons101
Post by Dons101 » Fri Sep 25, 2020 9:08 am
Great Upgrades and photos,
Nice to see a fellow Irish Fisherman on here.
I've just joined and I am amazed at all the build threads
Talk soon
Caddy Maxi Navy Blue, restless, avid traveler.
Would rather hike in the mountains, fish in the sea, canoe in a lake or river than surf a couch.
Post by FishermansFriend » Fri Sep 25, 2020 11:53 am
Hi Dons101,
Thank you. Yes I am fishing mad, out every week. Since I got the van my catch rate has drastically decreased, haven't landed a fish since June. When I am out on the bank I really enjoy reading the great build treads on here and it affecting my fishing :lol:
