Page 21 of 53
Posted: Wed Mar 24, 2021 9:07 am
by FishermansFriend
Ok, yes. You do need a certain amount of posts before you can access parts of the forum . Have a read over this page, it has the info about getting access
https://www.caddy2k.com/forum/viewtopic.php?f=3&t=31039
Posted: Fri Apr 02, 2021 12:25 pm
by FishermansFriend
Got the rear TRW GTI calipers, carriers and 286mm EBC discs installed. The process turned out to be a nightmare due to the first mechanic I too it to. I ended up buying a new ABS to replace the one he had supposedly refurbished. Then my brake servo went so had to replaced that, the heatshield off the servo was just lying in the bonnet and one of the bolts was loose and that's what caused it to brake. I'm only after getting my seats and floor mats clean of the brake dust.
Posted: Fri Apr 02, 2021 12:31 pm
by Doc
You've had a proper nightmare with those brakes, glad you're out the other side of it now.
Caddy is looking great.
Posted: Fri Apr 02, 2021 12:47 pm
by FishermansFriend
Hi Doc,
Thank you very much. I'm almost there. There was a clip broke on my handbrake cable he didn't tell me about, so just have to replace that now.
Posted: Sat Apr 10, 2021 1:13 pm
by FishermansFriend
Picked up Caddy Life Dash Vents in the cyclone (grey). I wrapped them in the 3M Matrix Black vinyl wrap to see how it would look, the plan was to have them sprayed pure grey but now I'm undecided.
Posted: Sat Apr 10, 2021 8:22 pm
by Lister79
I like the wrap mate, I’d personally leave them wrapped.
Posted: Sun Apr 11, 2021 4:37 pm
by FishermansFriend
The other piece didn't turn out as good
. More wrap on the way
Posted: Tue Apr 20, 2021 9:28 pm
by FishermansFriend
Finished off the Caddy Life dash vent trims today, the longer one was a pain, took me 5 attempts. I ended up separating the vents from the face so I could finish the wrap off nicely around the actual vent. Glued it back together with some Tiger Seal and used my old soldering iron to do a bit of plastic welding. The old vents popped out easy with a trim removal tool.
Posted: Sat May 01, 2021 6:27 pm
by FishermansFriend
Under body Sound Insulation installed, hoping it will keep the engine bay a bit cleaner.
Posted: Sun Jun 06, 2021 2:06 pm
by FishermansFriend
I've been really busy catching up with my fishing lately but I did have time to do the Wireless Charger mod with the help from the write up in the How To section of the forum.
Posted: Sun Jun 06, 2021 2:33 pm
by kneecap
@FishermansFriends. I'm looking at doing the same. Does it still charge with a case on? Also with my case on its slightly too long to sit flat do they have to be in direct contact to charge?? cheers
Posted: Mon Jun 07, 2021 10:31 am
by FishermansFriend
Hi Kneecap,
I don't have a case on my phone so I cant answer that one for you 100% but I'm sure the manufacturers would take the case into account. My phone is slightly to long also to sit flat but it still charges.
Posted: Mon Jun 07, 2021 10:51 am
by kneecap
That's perfect. I'll give it a go anyway as sick of wires everywhere
Posted: Mon Jun 07, 2021 9:47 pm
by ransomz0
I've been reading this thread with interest and intend to use it to make a to do list when mine arrives hopefully in the next week or so.
thanks for the info !
Posted: Thu Oct 21, 2021 6:15 pm
by FishermansFriend
The van passed its annual road worthy test last week with no issues, I had an advisory on a new tire so 4 new tires on the way.
I picked up the new style Dynamic Hub Caps to replace the other ones I had, these ones are black gloss finish and suit my rims a bit better. I also finally fitted the 5 speed gear knob badge I had for over a year now, it replaced the 6 speed that the knob came with, some Tiger Seal did the job.
The van is going into the garage tomorrow to have new rear shocks and 60mm Eibach loweing springs installed.
