The Poverty Spec Caddy
ACalamita
Post by ACalamita » Sun Sep 06, 2020 4:37 pm
Hi all,
Wanted a Caddy for years but couldn't always justify the price and having a Scirocco R as a daily was swallowing most of my money!
Not wanting to put a roof rack on the Scirocco, I looked at Caddy's but all seemed a little expensive. Came across a cheap-ish Touran that I thought would be as good as a Caddy (I was wrong lol!).
Was a bit too much of a family wagon despite the space with the rear seats all out.
Sold the Touran and managed to find a 130k 2012 facelift 1.6TDI.
Was originally a Stannah Stairlift engineers van and then owned by a valeter so relatively clean and looked after.
However... The water tank from the valeter seemed to have been emptied into the rear footwell when removed!! Once I removed the bulkhead, all was revealed.
Have a few plans to make it a bit less poverty/base van spec and more of a daily over the winter whilst I'm working on the other two cars over the winter.
Starting with some sound deadening, carpet/ply rear and Touran rear seats.
I have a set of cruise control stalks from a mk6 in the garage that may fit with the right steering wheel control module. Need to check with VCDS first though.
Doesn't have an MFD currently as there's not buttons on the stalk but does anyone know if it can be enabled with VCDS and a stalk with switches on? Or is a new cluster needed?
Anyway... Enough for now, here's some pics!
Papa Bear
Re: The Poverty Spec Caddy
Post by Papa Bear » Sun Sep 06, 2020 4:48 pm
My cluster wasn’t mfd but is now I’ve changed the stalks and coded them
Depends on the cluster though.
Black
Marmite lover!!!
VCDS
ACalamita
Post by ACalamita » Sun Sep 06, 2020 5:18 pm
Cool!
From experience with other VWs, I thought that might be the case!
Will plug it into VCDS later and check the long coding. Presume it's an option in there or adaptations.
Papa Bear
Post by Papa Bear » Sun Sep 06, 2020 5:50 pm
Tbh, my memory is shot but believe I had to tick 2 boxes to get it working :D
By the way, nice van to mod!
Poverty spec means you can have a longer list :)
Black
Marmite lover!!!
VCDS
ACalamita
Post by ACalamita » Sun Sep 06, 2020 6:49 pm
There could well be!
Just dug my mk6 stalks out of stock. They're cruise as I thought but no MFD switches so would need an MFD.
Seems my steering wheel module MAY or MAY NOT work with cruise too according to the Ross Tech table of steering wheel modules.
True! It does mean a longer list and more to do but least I'll be able to make it my own in the process :)
It's a good solid base to start with too!
Papa Bear
Post by Papa Bear » Sun Sep 06, 2020 8:58 pm
Mines a 2011 facelift, said the same
Worked fine though.
Black
Marmite lover!!!
VCDS
ACalamita
Post by ACalamita » Sun Sep 06, 2020 9:21 pm
Yeah, I've had previous ones in the past that have and others that haven't. All depends on hardware revision.
I've coded it in so will see when I take it for a drive. No light on dash yet though when it's switched to "On".
ACalamita
Post by ACalamita » Mon Sep 07, 2020 9:48 pm
Managed to get hold of the Touran rear setup today. Minus the carpet and seatbelts. Seats need a good clean too!
Took out the telematics and the horrible bluetooth adapter.
And finally got the right stalks so I can have cruise and use the MFD properly :)
ACalamita
Post by ACalamita » Tue Sep 08, 2020 11:24 pm
Passenger side underlay refitted now it's been drying in the house for 5 days... and Mk5 GTI seats in!
Managed to source some more Touran rear seats (cleaner than the first set) and both rear carpet sections, seatbelts and more plastics.
Weekend job will be fitting all that!
ACalamita
Post by ACalamita » Sun Sep 13, 2020 8:40 pm
Today's job... Touran rear seat base in!
Managed to get the front part welded in. Just need some fixings for the rear piece (will get some tomorrow hopefully) too and then chuck a few welds on that too.
I'm still patiently waiting full access to the forum so only seen pictures of it completed but it's a nice straightforward job.
The hardest part was drilling the spot weldsand separating the two Touran pieces as the breakers had just cut the floor of the Touran around the base bracket with a grinder.
Also, started colour coding with the rear door handle cover thingy! That's currently drying with it's clear coat on in the garage.
Lamby00
Post by Lamby00 » Tue Sep 15, 2020 11:00 am
Good progress here mate. Good job
kafer-k
Post by kafer-k » Wed Sep 16, 2020 2:25 pm
Looking really good, do the Touran middle row seats fold completely flat? Just thinking about using them as part of a bed set-up.
ACalamita
Post by ACalamita » Wed Sep 16, 2020 8:36 pm
Thanks dude!
Progress had slowed due to work and other commitments.
But managed to get the rear grab handle thingy lacquered and fitted. Touran rear plastics trimmed and fitted with the Caddy step and the carpet in temporarily until I ply/carpet the rest.
Seatbelts next! Had some bolts in stock but waiting on some spreader plates to finish it off. Managed to not have the belts twisted and fit relatively OEM like.
Will post up more details in the how-to thread once it's all done.
Think next on the list is the rest of the rear... Sound deadening and ply and carpet!
Then can move onto lowering and the outside :D
Already have some 18" BBS wheels to go on :)
Towner11
Post by Towner11 » Wed Sep 16, 2020 9:37 pm
Looking good
ACalamita
Post by ACalamita » Wed Sep 16, 2020 10:10 pm
Thanks!
Not much of a looker yet but getting all the boring and practical stuff out the way first :D
